https://auszookers.com/forum/
front arb air locker
https://auszookers.com/forum/viewtopic.php?f=5&t=54575
Page 1 of 2
Author:  greavesyzook [ Wed Sep 13, 2017 1:02 pm ]
Post subject:  front arb air locker
I just brought an air locker Is it worth upgrading axles and stuff aswell?
Author:  Gwagensteve [ Wed Sep 13, 2017 1:26 pm ]
Post subject:  Re: front arb air locker
Yes, definitely, but once you do that thou don't use a front airlocker to go in the front, you use a rear.
Front= 22 spline axles
Rear= 26 spline axles.
All upgraded front axles are 26 spline.
Author:  greavesyzook [ Wed Sep 13, 2017 1:57 pm ]
iv orderd a front locker so is the locker 26 spline to?
Author:  greavesyzook [ Wed Sep 13, 2017 3:03 pm ]
I'll change my order and get a rear for the front then with a new set of axles
Author:  lgp29 [ Wed Sep 13, 2017 3:23 pm ]
Threw an auto locker in the front of mine and killed a stock cv first time I really used it in anger.
Running chromo cv's and axles now which are all 26 spline. All the zooks I know that ran stock cv's and axles have had failures when locked.
Author:  greavesyzook [ Thu Sep 14, 2017 9:17 am ]
Will the rear locker fit in the front diff ok? Do I need to change the spider gears to?
Author:  MrRocky [ Thu Sep 14, 2017 9:27 am ]
The arb locker replaces everything except r&p
I ran rear arb up front no issues, stock axles dont last so chromos and rear arb up front are a good move first up
Author:  greavesyzook [ Thu Sep 14, 2017 10:13 am ]
Good iv ordered all the stuff I just like to check with others to make sure lol
Author:  alien [ Thu Sep 14, 2017 12:57 pm ]
You'll love it!
Word of advice - once you get the front locker in and working - drive some really easy tracks with it locked so you get a feel for how the steering behaves, because it's VERY different on loose surfaces, and VERY heavy on high traction surfaces (ie: slows down your steering response).
Author:  greavesyzook [ Thu Sep 14, 2017 1:52 pm ]
Yeah I'm keen! Always just had mini spool in the rear and it goes everywhere with it so keen to see where I can drive with a locker ;)
Author:  alien [ Thu Sep 14, 2017 4:21 pm ]
Short answer: Into far more precarious situations!!!
Author:  Lebowski [ Thu Sep 14, 2017 11:27 pm ]
Make sure your ARB installer routes the internal (inside diff) lines properly as per ARB pattern.
The diff guy I used (reputable) routed it like a Dana44/60 and it hence the internals of the Sierra diff housing had to be notched to clear the ARB metal air line. :|
I upgraded to RCV 26 spline shafts.
Author:  Gwagensteve [ Fri Sep 15, 2017 5:29 am ]
Most diff installers would almost never see a D44 or D60 in Australia.
Author:  greavesyzook [ Fri Sep 15, 2017 9:28 am ]
Im just getting the arb dealer in town to do it. Yeah ain't d44/60 American?
Author:  MrRocky [ Fri Sep 15, 2017 9:31 am ]
The new design arb sierra locker (old patent is used by chinasoong air lockers) is much better regarding routing of the copper line. Any competent mech should be able to do it no dramas, arb offer a 5yr warranty when they do the install had one done last week on the daily
Author:  greavesyzook [ Fri Sep 15, 2017 10:55 am ]
What's the difference between the old design and the new one?
Author:  MrRocky [ Fri Sep 15, 2017 12:39 pm ]
The way the copper hose is run and other small differences
Its more that the patent run out on the old design hence chinasoong lockers are a direct copy of the old arb design
Author:  greavesyzook [ Fri Sep 15, 2017 3:07 pm ]
What's the difference in price on the Chinasoong locker?
Author:  MrRocky [ Fri Sep 15, 2017 3:52 pm ]
Half price
Author:  greavesyzook [ Fri Sep 15, 2017 7:41 pm ]
They be a good buy then
Author:  MrRocky [ Fri Sep 15, 2017 9:01 pm ]
Perhaps...
Author:  greenzook89 [ Sun Sep 17, 2017 12:14 am ]
Thats like saying a CAP locker would be a good buy because its a few hundred cheaper.
Author:  fordem [ Sun Sep 17, 2017 8:50 am ]
Is it? Once I factor in the shipping, I figure I could get a genuine ARB air locker for about the same thing a CAP locker would cost me.
Author:  henno [ Sun Sep 17, 2017 8:57 am ]
The aussie dollar is the major determining factor, but they aren't half price. They are usually within a few hundred dollars ($700-ish versus $950 for the ARB).
That includes a compressor of course, but that are hardly good quality. Probably fine to turn a locker on and off for a while but when used to air up and down they seem to die a very quick death.
Author:  greavesyzook [ Sun Sep 17, 2017 9:28 am ]
Mmm the old saying goes ya get what you pay for haha
Author:  henno [ Sun Sep 17, 2017 11:45 am ]
I don't think anyone has actually had any issues (compressor notwithstanding) but I spent my money on a second hand genuine ARB instead.
Author:  greavesyzook [ Sun Sep 17, 2017 2:52 pm ]
Yeah atleast I can take it back to town if something buggers up with the arb one
Author:  Marn [ Sun Sep 24, 2017 5:06 pm ]
Do the ARB lockers fit the coily diffs? Im not sure if they are a different diff or the same. Thanks
Author:  greavesyzook [ Sun Sep 24, 2017 6:52 pm ]
just the rear i think?
Author:  greenzook89 [ Sun Sep 24, 2017 10:35 pm ]
Yes just the rear.
Page 1 of 2 All times are UTC + 9:30 hours
