It is currently Sat Oct 10, 2026 2:04 pm
Vehicle: 96 tin top sierra 31's omes
Post Posted: Mon Sep 18, 2017 12:35 pm
Hey has anyone made the sierra ac work with a different pully after doing the g16b swap?
Or do you just change the compressor
Sent from my SM-G900I using Tapatalk
Post Posted: Tue Sep 19, 2017 2:02 pm
I couldn't find a multi-rib pulley to suit the sierra a/c compressor, so I just ended up running a g16b vitara a/c compressor on the factory vitara aircon/power steering brackets.
79' LJ80 (sold) :(
95' & 97' sierra (sold)
Post Posted: Tue Sep 19, 2017 8:52 pm
Awesome. I think thats what i will look into.
Did the hoses fit?
Post Posted: Wed Sep 20, 2017 7:03 am
I'm going to run the complete Baleno setup as it came out of the car, p/s pump and A/C compressor. I just plan to modify all hoses to fit
Post Posted: Thu Sep 21, 2017 2:12 am
Did the hoses fit?
Yep all the factory sierra A/C hoses hook up. If you're running a vitara power steering pump on the bracket it will position the pump lower, so the radiator support mount on the chassis needs to moved forward/modified so the pump doesn't fowl it.
79' LJ80 (sold) :(
Vehicle: WT sierra, GU CRD
Post Posted: Thu Sep 21, 2017 11:13 am
Anyone running the power steer and A/C from the Vit G16B in a sierra?
Cheers,
Mark
I love ZD30. :)
Vehicle: Drover pickup turk
Post Posted: Thu Sep 21, 2017 1:38 pm
If I recall correctly jr.zook was, Mark.
Jake, I've got that baleno compressor here if you want it, no mount for it though.
I like the tuna here
Post Posted: Thu Sep 21, 2017 9:58 pm
Yes please
Post Posted: Fri Sep 22, 2017 9:12 am
Thanks Blkfxx. Will check out his thread yet again.
I love ZD30. :)
Users browsing this forum: No registered users and 104 guests
