https://auszookers.com/forum/
Sierra fuel filler neck hose ....41mm or 44mm?
https://auszookers.com/forum/viewtopic.php?f=5&t=54648
Author:  Lebowski [ Fri Sep 29, 2017 4:01 am ]
Post subject:  Sierra fuel filler neck hose ....41mm or 44mm?
The main filler neck on the Sierra metal fuel tank, would that take a 41mm or 44mm inside diameter hose?
My old tank was rotted so it is gone, and new tank has been ordered.
Thanks in advance.
Author:  bumstein [ Fri Sep 29, 2017 9:23 am ]
Post subject:  Re: Sierra fuel filler neck hose ....41mm or 44mm?
The filler neck measures in at 42mm
Author:  Lebowski [ Fri Sep 29, 2017 10:54 pm ]
I'll go for the 41mm fuel hose.
Thanks!
Author:  steve125 [ Sat Sep 30, 2017 5:27 pm ]
Are you talking about the rubber hose that fits between the body and the tank? From memory it's a wider diameter at the body end.
Author:  Lebowski [ Sun Oct 01, 2017 7:36 am ]
Yes, that is the correct hose...filler cap to fuel tank hose.
The body end I am modifying, so it is the tank end I am referring to for mm size.
I was aware it was a tapered hose, but thanks for pointing that out and looking out for me. :-)
