| Axle shaft defect https://auszookers.com/forum/viewtopic.php?f=5&t=5466 |
| Author: | Damo [ Tue Jul 07, 2009 1:09 am ] |
| Post subject: | Axle shaft defect |
Was changing the wheel bearings on my rear axle shafts today and noticed something on one of them
I think what's happened is that some water has got in under the retaining ring and it's corroded the metal away. Unless it's a defect from the factory that's the only explanation I can come up with. |
| Author: | TZAR [ Tue Jul 07, 2009 1:19 am ] |
| Post subject: | Re: Axle shaft defect |
It could have been that someone welded the retaining ring to try and get it off and got a bit excited when they did it, maybe by about 100 amps too much OR they used a grinder and cut the retaining ring too far and then welded it back up OR some rock ape with a 12 pound hammer and a 1 inch cold chisel try knocking the ring off ( would have to be a pretty strong cold chisel. Either way I would say that axle is shepped...... |
| Author: | Damo [ Tue Jul 07, 2009 1:23 am ] |
TZAR wrote: It could have been that someone welded the retaining ring to try and get it off and got a bit excited when they did it, maybe by about 100 amps too much
OR they used a grinder and cut the retaining ring too far and then welded it back up OR some rock ape with a 12 pound hammer and a 1 inch cold chisel try knocking the ring off ( would have to be a pretty strong cold chisel. Either way I would say that axle is shepped...... We'll find out if I ever get to do some destructive testing! |
| Author: | shep [ Tue Jul 07, 2009 1:24 am ] |
TZAR wrote: Either way I would say that axle is shepped...... if ya cant see it when it is in the housing it isn't really there. it would be fine to reuse it. probably. i would anyway. |
| Author: | Damo [ Tue Jul 07, 2009 1:47 am ] |
shep wrote: TZAR wrote: Either way I would say that axle is shepped...... if ya cant see it when it is in the housing it isn't really there. it would be fine to reuse it. probably. i would anyway. If it helps I was sitting on a upturned milk crate at the time |
| Author: | shep [ Tue Jul 07, 2009 1:50 am ] |
Damo wrote: shep wrote: TZAR wrote: Either way I would say that axle is shepped...... if ya cant see it when it is in the housing it isn't really there. it would be fine to reuse it. probably. i would anyway. If it helps I was sitting on a upturned milk crate at the time well you will have no dramas then. |
| Author: | dank [ Tue Jul 07, 2009 2:07 am ] |
damo thats no probs mate....I had to go to an engineer to get my old retaining rings off a few years back and the stoopid idiot got stuck into the retaining rings with a 9 inch grinder and proceeded to cut a nice groove into my axle shaft...a lot worse than what yours is. We just put the new bearing and retaining ring on and I've driven it for 3 years afterwards and it has been no issue. Running 34s and no breakage...in the time that it was runnign before my engine swap... |
| Author: | Damo [ Tue Jul 07, 2009 11:55 am ] |
dank wrote: damo thats no probs mate....I had to go to an engineer to get my old retaining rings off a few years back and the stoopid idiot got stuck into the retaining rings with a 9 inch grinder and proceeded to cut a nice groove into my axle shaft...a lot worse than what yours is. We just put the new bearing and retaining ring on and I've driven it for 3 years afterwards and it has been no issue.
Running 34s and no breakage...in the time that it was runnign before my engine swap... It is a pretty chunky part of the shaft. It could cause a problem if it's made a stress point. Cool that yours survived for so long after being butchered!! |
