It is currently Sat Jul 25, 2026 11:51 pm
Post new topic Reply to topic  [ 33 posts ]  Go to page 1, 2  Next
Vehicle: 1992 suzuki sierra hardtop
Post Posted: Sun Aug 27, 2017 5:47 pm
i will pay someone to come finish the wirering on my zook im desprate please help :deadhorse:
Vehicle: 95 Sierra Soft top
Post Posted: Tue Aug 29, 2017 4:13 pm
Suziworld has sent my GTI wiring loom up to QLD to get done, was told it would cost about $600 and take 2-3 weeks, going on the 7th week now, call Mick from SuziWorld, I don't think his to happy with the service as well
Post Posted: Wed Aug 30, 2017 12:18 pm
Yeah that would be that kustom kables crew wouldn't it?
Post Posted: Wed Aug 30, 2017 12:33 pm
Iv got everything hooked up the injectors are playing dirty theres no injector pulse she'll fire for 3 seconds then cut out
Post Posted: Wed Aug 30, 2017 12:40 pm
Let's look at that last statement closely - there's no injector pulse, she'll fire for 3 seconds then cut out - what does that mean - that you get an injector pulse for three seconds?
Going from memory, if there is no ignition feedback, the ECU shuts the injection down to prevent flooding - injection feedback is provided by a noise filter near the igniter - is that hooked up?
Post Posted: Wed Aug 30, 2017 12:57 pm
Yeah there's a pulse for 3 seconds then cuts out yeah noise filter is hooked up
Post Posted: Wed Aug 30, 2017 11:13 pm
Do you have the CEL hooked up? Insert the diagnostic jumper and crank the engine and then count the flashes before switching the ignition off - if you get a 41 that would indicate that the ECU is not seeing the ignition feedback from the noise filter.
Post Posted: Wed Aug 30, 2017 11:15 pm
Will try this cheers mate
Vehicle: Twin cam Sierra
Post Posted: Fri Sep 01, 2017 12:13 pm
I had this issue with the noise filter not hooked up correctly,Wired one in and it started.
Twin Cam Sierra 4" lift 31's
Post Posted: Fri Sep 01, 2017 1:25 pm
Iv got my noise filter hooked up where did yours go to on the ECU?
Post Posted: Sat Sep 02, 2017 1:26 pm
Still no go! I'm still thinking injector pulse would it be worth pulling the injectors??
Vehicle: 1995 suzuki sierra hardtop
Post Posted: Sat Sep 02, 2017 2:39 pm
How did you hook up the noise filter? Did you splice into the original?
Post Posted: Sat Sep 02, 2017 3:02 pm
Yes spliced into original. But not sure if iv Done the right wire which one does it tap into?
Post Posted: Sat Sep 02, 2017 9:57 pm
Why? What difference would pulling the injectors make?
The injector pulse is how the ECU controls the injectors, if there is no pulse, the injectors won't open, and no fuel will be injected.
What you need to do is find why there is no injector pulse, and if you have spark but no injector pulse, it will almost always be because the ECU is cutting the injection, I've already given you the most common reason, and the way to test for it - if you have a code 41, it'll be because the ECU is not seeing the ignition, if there is no code (code 12), then the possibilities are a defective ECU or a damaged harness between the ECU and the injectors.
Post Posted: Sun Sep 03, 2017 5:58 am
Iv got spark and iv pulled out the plugs to see if there wet with Fuel and they were
Post Posted: Sun Sep 03, 2017 10:06 am
Soooo ...
a - how is the fuel getting into the chambers if there is no injection pulse?
b - why do you say there is no injection pulse?
c - have you tried running it on starter fluid?
d - have you verified the ignition timing and firing sequence?
As far as I'm aware the GTi runs a "batch fire" injection system - all four injectors fire simultaneously, so if it's fuelling and won't start, it's more likely to be a spark issue (because the spark timing/sequence is critical),
Post Posted: Sun Sep 03, 2017 12:14 pm
Can't remember which wire to splice into, it's not the black ground wire which I think is in the centre IIRC. Which one have you got it spliced to atm?
EDIT: Hard to read wiring diagrams on the internet but looks like Brown wire from Swift ecu pin A12 should be spliced into Brown wire (not br/w) coming out of noise filter.
Post Posted: Sun Sep 03, 2017 4:49 pm
Yep that's right my bf is hooked up to that one. I'm gunna check the dizzy ect see if there's something up with that.
Post Posted: Sun Sep 03, 2017 6:13 pm
can i do the ignition timing the same as the old 1.3 carby engine?
Post Posted: Mon Sep 04, 2017 12:54 pm
You do have the ignition leads hooked up the right way? As in 1-3-4-2?
Post Posted: Mon Sep 04, 2017 2:33 pm
Yep that's all right with new leads and new spark plugs
Post Posted: Mon Sep 04, 2017 3:15 pm
So you've verified that you have spark?
And you've put a multimeter on the injector plugs to verify they're firing?
When you say 'it fires for 3 seconds' is the car actually starting and then cutting out or is it just the injectors running for 3 seconds?
Are you running the angle drive dissy or maza cap?
Post Posted: Mon Sep 04, 2017 3:27 pm
Yeah got spark. It kicks over like all the injectors are doing there job then just stops got the angle drive dizzy
Post Posted: Tue Sep 05, 2017 8:17 am
Still not that clear...
When it starts is it running smooth like you have all 4 cylinders firing? Or is it coughing and spluttering then dying?
If you have spark and fuel then I think it can only be;
-No feedback to ECU
-Timing out i.e leads on wrong cylinders, timing belt installed wrong, crank keyway sheared
Post Posted: Tue Sep 05, 2017 9:42 pm
Coughing and spultering then dying.
Iv found a Problem with the rota button which wouldn't be helping. I didn't install the dizzy so never noticed it before
Post Posted: Wed Sep 06, 2017 9:42 am
Sounds like you're getting closer then. May only be running on 2 cylinders so I'd be checking spark and fuel on each cylinder and also checking for blocked injectors if the rota button doesn't fix it
Post Posted: Wed Sep 06, 2017 10:00 am
I'm itching to get back on the track's it's been so long hahah
Post Posted: Sat Sep 09, 2017 3:40 pm
Well the injectors aren't blocked ffs
Post Posted: Thu Oct 05, 2017 2:38 pm
I'm still having problems it won't run!! Any other ideas?
Vehicle: Vitara 1994
Post Posted: Thu Oct 05, 2017 9:13 pm
Sounds to me like fuel pump. If they sit around for a while they are garbage. Does it have a new pump in it?
Users browsing this forum: No registered users and 106 guests
