https://auszookers.com/forum/
Throttle Cable Fitment
https://auszookers.com/forum/viewtopic.php?f=5&t=54831
Author:  DaveA [ Thu Nov 23, 2017 4:07 am ]
Post subject:  Throttle Cable Fitment
I received my new throttle cable from 4WD Products last night and will fit it this weekend.
Just a question regarding how it fits at the firewall end.....
It has a white plastic "plug" with four clips and a rubber washer. Does this just clip into the firewall when you insert it from the engine-bay side?
Author:  Gwagensteve [ Thu Nov 23, 2017 6:22 am ]
Post subject:  Re: Throttle Cable Fitment
Yes, correct.
They can be a bit fragile and prone to breaking (the clips) so be careful.
Author:  DaveA [ Thu Nov 23, 2017 1:15 pm ]
Thanks mate!
So, best to wiggle it in gently, huh?
Would it help if I lubed the hole first?
Author:  BlueSuzy [ Fri Nov 24, 2017 8:37 am ]
You can jam it in dry
Author:  DaveA [ Fri Nov 24, 2017 9:49 am ]
Yeah, just don't want to break any of the clips, hence thought some lube might help me to ease it in gently.
Author:  bumstein [ Fri Nov 24, 2017 10:32 am ]
Lube is always good [emoji3]
But really with or without lube if your not heavy handed it should be fine
Author:  Gwagensteve [ Fri Nov 24, 2017 3:54 pm ]
I've found it's more a problem of the firewall doubling plate can be quite snug around the cable which can make it hard to align, and its very hard to get them out without breaking the clips, so make sure you're happy before you put it in
Author:  DaveA [ Fri Nov 24, 2017 6:51 pm ]
I just had a look and the hole is in a bugger of a place there under the brake booster! There's not a lot of room for my fat fingers!
