It is currently Wed Oct 21, 2026 8:46 am
Post Posted: Thu Jul 09, 2009 12:28 am
Hi all,
Though id try here s im not having luck elsewhere. Where do these hoses go to ? Does this cut hose go to the brake booster?
Also cant figure out where this one goes?
Any ideas?
Thanks
Post Posted: Thu Jul 09, 2009 1:35 am
First photo, you got it, booster.
Post Posted: Thu Jul 09, 2009 1:36 am
second pic needs hot water.
Post Posted: Thu Jul 09, 2009 1:38 am
yup first hose is booster,and the second hose is fed from the thermostat housing runs through the idle up unit and down to the pipe at the back of the waterpump...if can help wth anything else let me know as i have done this conversion :lol: except mne is turbo :wink:
Coily GTI Turbo...thats right its a coily!!
Post Posted: Thu Jul 09, 2009 10:38 am
Is that a Mk.1 GTi motor?
Mine has the same idle control thingy.
Post Posted: Thu Jul 09, 2009 1:35 pm
Its apparently a Mk3 motor.
That pulsr site has crashed so there are no good pics anywhere anymore
Post Posted: Thu Jul 09, 2009 4:42 pm
Is this the link you had?
http://pulsr.net/g13b/
It worked for me a minute ago.. Give it another crack
Post Posted: Thu Jul 09, 2009 8:15 pm
Thats funny. I was trying that site for the last few days and couldnt get it to work.
He mentions to block one of the pipes from behind the water pump and so did chinny in his build up. I used the pipe they blocked off to run the inlet manifold hose im pointing to in the picture.
Wonder what chinny did with that hose as his was a Mk3 motor?
The one on the pulsr website has a different inlet manifold being a Mk1.
Post Posted: Thu Jul 09, 2009 8:28 pm
To keep the tech going the little green outlets have been pointed out to be on another forum as the egr valve, that little red/brown thing with 2 hose barbs on it. One goes to the charcoal canister, the other to your inlet manifold.
Do i need to hook these up for an unregoed vehicle? Where do they go exactly?
Any side effects of not having them hooked up?
Post Posted: Thu Jul 09, 2009 8:59 pm
I am pretty sure the EGR one doesn't go to the charcoal canister. If it is for EGR then it will activate a valve that circulates exhaust gas into the inlet (EGR = exhaust gas recirculation). The one that connects to the charcoal canister purges fuel vaour from there into the inlet manifold.
For an unregistered vehicle you don't really need to worry about them.
Users browsing this forum: No registered users and 192 guests
