Joined: Sat Aug 27, 2016 7:52 pm Posts: 37 Location: South Australia
Vehicle: LWB tray top G13B
Posted: Sun Jan 07, 2018 5:46 pm
So, I'll run down the info
- car wont idle nice unless timing is set on 8deg - the idle up for lights/demisters puts it at 2,500rpm - valves are adjusted to middle of specs - car was running fine, drove through a puddle, died, adjusted valves and timing, let it sit for a few days ran fine for a few mins then started with the lumpy idle (misses on 3 we think), since then has been so much fiddling with everything and its been off and on - car does run fine above 2000rpm, even once off idle it runs fine however is a teeny tiny bit 'rough' (you can just feel the vibration)
Is it worth just taking it to a mechanic? It's needed a carby rebuild from day dot, should we just rebuild it? It has a new ebay dizzy (the old dizzy crapped out when a lead was pulled off) should we try a OEM dizzy and/or get a new coil? Or just screw it all and G16A swap it lol? (I'd prefer G16B but it's my mothers car and she prefers carb)
Joined: Thu Mar 29, 2007 11:30 pm Posts: 14498 Location: Here there everywhere
Posted: Sun Jan 07, 2018 7:49 pm
Need to pull the carby apart and clean it paying special attention to the idle circuit. Actually might pat to make sure you can hear a clicking sound from the carby when turning the ignition on and off
Users browsing this forum: No registered users and 182 guests
