It is currently Tue Oct 20, 2026 11:41 am
Post Posted: Thu Feb 01, 2018 6:44 pm
I'm guilty of never measuring the pre-load for the kingpins when I had the swb. Always ran with no shims :roll:
But I got to thinking if I was to set the pre-load to specification as per the fsm, wouldn't it make a difference on a larger tyre such as a 33 considering the the stock tyre size is a 26? Much larger and heavier.
Again, most likely overthinking and over analysing.
Phuck Photobucket
Post Posted: Thu Feb 01, 2018 10:30 pm
Start with 2 shims top and bottom, if you get the shakes remove a top shim and so on... until wobble goes haha
Vehicle: G16b sierra
Post Posted: Fri Feb 02, 2018 1:36 pm
Works on patrols really well
Post Posted: Fri Feb 02, 2018 2:03 pm
You’re correct, but if you go too high the bearing will get notchy and this can trigger wobble too.
Users browsing this forum: No registered users and 181 guests
