| Which VL mounts to use in Swift GTi conversion... https://auszookers.com/forum/viewtopic.php?f=5&t=55000 |
| Author: | Toomanycars [ Tue Feb 06, 2018 1:13 pm ] |
| Post subject: | Which VL mounts to use in Swift GTi conversion... |
I know it is the V6 VL commodore engine mounts that get used in a Swift GTi engine conversion... Is it auto or manual VL mounts.. Part numbers would be excellent if someone has them.. We have got everything I think except new mounts... Cheers.. |
| Author: | MrRocky [ Tue Feb 06, 2018 1:46 pm ] |
| Post subject: | Re: Which VL mounts to use in Swift GTi conversion... |
Rb30e mount 3ltr straight 6 Should all be the same |
| Author: | Toomanycars [ Tue Feb 06, 2018 4:33 pm ] |
Bursons recon the man and auto are different.. Thanks for the part number...Gives me somewhere to start.. |
| Author: | steve125 [ Tue Feb 06, 2018 7:22 pm ] |
I used ones that looked like this Kelpro mount. Had to grind the small tab off to fit.
| Author: | greavesyzook [ Wed Feb 07, 2018 3:44 pm ] |
I just use the normal 1.3 mounts |
| Author: | MrRocky [ Wed Feb 07, 2018 4:22 pm ] |
Most aftermarket standard ones are pretty weak. When you swap to higher hp efi motors the passenger side mount busts all the time as thats the way the engine torques. Ive had success using the repco ones but all the other ones would bust quickly. The vl mounts are good but can be a tight squeeze to fit on your own, an extra set of hands makes it a bit easier |
| Author: | Toomanycars [ Wed Feb 07, 2018 11:20 pm ] |
Yes normal engine 48hp... gti is 101hp... so breaking mounts is common.. |
| Author: | greavesyzook [ Thu Feb 08, 2018 4:45 am ] |
Iv never broken one yet after about 5 engine swaps |
| Author: | MrRocky [ Thu Feb 08, 2018 6:18 am ] |
Guess it depends on your driving style |
| Author: | Kfal [ Thu Feb 08, 2018 1:20 pm ] |
MrRocky wrote: Guess it depends on your driving style ie skids or no skids |
| Author: | greavesyzook [ Thu Feb 08, 2018 2:05 pm ] |
Yeah if ya gunna flog it a 7000rpm |
| Author: | Toomanycars [ Thu Feb 08, 2018 2:41 pm ] |
The car needs new mounts anyway so why not put in stronger ones if they are around the same price ??? $58 delivered.. |
| Author: | JrZook [ Mon Feb 12, 2018 10:52 am ] |
MrRocky wrote: Most aftermarket standard ones are pretty weak. This! If they don't bust (where the rubber-metal vulcanizing bond fails as opposed to the rubber tearing in genuine Japanese mounts) under moderate stress they end up sagging heaps! Same goes for aftermarket transfer case mounts |
