| cheap effective mods https://auszookers.com/forum/viewtopic.php?f=5&t=5560 |
| Author: | money_killer [ Wed Jul 15, 2009 12:26 am ] |
| Post subject: | cheap effective mods |
hey guys just after ur opinions on wat are cheap effective mods performance and capabilitly wise for the budget weekend warrior my first thought is locking the rear up which im doing atm |
| Author: | money_killer [ Wed Jul 15, 2009 12:29 am ] |
| Post subject: | Re: cheap effective mods |
another question is it worth putting a set of extractors on ? and wat exhaust size do uses guys normally run car is a 90 WT Soft top 1.3L |
| Author: | 11_evl [ Wed Jul 15, 2009 12:44 am ] |
weld rear diff. get some tready tyres. longer shocks and brakelines. thats it |
| Author: | money_killer [ Wed Jul 15, 2009 1:14 am ] |
11_evl wrote: weld rear diff. get some tready tyres. longer shocks and brakelines. thats it
exactly wat i was thinking. got diff centre out atm. getting if welded up on thurs when u say longer shock's how much longer then normal? should i chuck on some f & r extended shackles also or they not needed. aaron |
| Author: | Zook_Fan [ Wed Jul 15, 2009 1:15 am ] |
for cheap yes you could go longer shackles, but for effectiveness stay away from them unless going longer springs. |
| Author: | Damo [ Wed Jul 15, 2009 1:19 am ] |
Some good tips in here |
| Author: | nick.gooding [ Wed Jul 15, 2009 2:57 pm ] |
go with the hilux commodore shocks someone whos nos more about? good flex take out a leaf or 2 all round |
| Author: | 11_evl [ Wed Jul 15, 2009 5:35 pm ] |
Inboard the rear shocks and use as long as will fit with out bottoming shock. Shock hoops or make the stock front mounts longer than do the sAme, fit longer shocks. Tape measure is your friend |
| Author: | money_killer [ Wed Jul 15, 2009 10:44 pm ] |
cheers thanks i should have searched a bit better |
| Author: | Damo [ Thu Jul 16, 2009 11:34 am ] |
money_killer wrote: cheers thanks
i should have searched a bit better Plenty of info on Auszookers, a search generally will pull up a lot of info unless you're after something obscure. Having said that, it's still OK to ask |
| Author: | Scrawny [ Thu Jul 16, 2009 12:59 pm ] |
Damo wrote: money_killer wrote: cheers thanks i should have searched a bit better Plenty of info on Auszookers, a search generally will pull up a lot of crap unless you're after something obscure. Having said that, it's still OK to ask Fixed Damo |
| Author: | Damo [ Thu Jul 16, 2009 1:40 pm ] |
ScrawnC wrote: Damo wrote: money_killer wrote: cheers thanks i should have searched a bit better Plenty of info on Auszookers, a search generally will pull up a lot of crap unless you're after something obscure. Having said that, it's still OK to ask Fixed Damo Yeah and most of the crap is non-tech BS posted by Scrawn Oh, and milk crate stuff. |
| Author: | Scrawny [ Thu Jul 16, 2009 1:42 pm ] |
Damo wrote: ScrawnC wrote: Damo wrote: money_killer wrote: cheers thanks i should have searched a bit better Plenty of info on Auszookers, a search generally will pull up a lot of crap unless you're after something obscure. Having said that, it's still OK to ask Fixed Damo Yeah and most of the crap is non-tech BS posted by Scrawn Oh, and milk crate stuff. What do you mean most?? I claim it all!! |
