It is currently Tue Oct 20, 2026 9:10 pm
Vehicle: SJ80
Post Posted: Wed Jul 15, 2009 10:52 pm
Hey guys, got a bit of a noise in my sierra. Only occurs when there is slight stress on the body, ie: turning, braking and accelerating. But not all the time. The noise itself sounds like someone hitting the floor of the cab with a hammer and only once at a time. Thinking it has to do with suspension moving around or body shifting on mounts. Pretty sure it's the latter as it really only became noticable after the body lift. Now I've been under it twice and retightened eveything. It went away for a while but returned after I had it up on the jack changing a tyre. Hence the possibility of it being suspension. Anyone else experinced anything similar? Suspension is 40mm ome kit with ext shackles if this makes a difference. Cheers.
Bronson
Post Posted: Thu Jul 16, 2009 12:57 am
I has a smilar thing on my old 93 sierra ute....it was the bodylif...pushed the floor in where it bolted on...check the mounting points on the body...make sure it hasn't broken through......could be somthing else,but it sounds like wat I had
Coily GTI Turbo...thats right its a coily!!
Post Posted: Thu Jul 16, 2009 1:52 am
when noises, creeks, bang ect DONT happen thats when you get worried :lol:
Post Posted: Thu Jul 16, 2009 2:00 am
I dont hear any of those noises. I run silverstone extremes. :roll: :roll:
Post Posted: Thu Jul 16, 2009 2:03 am
lol i am the same. i have started wearing muffs when i drive. :lol:
Vehicle: 98 coily..Max.
Post Posted: Thu Jul 16, 2009 3:00 am
Are you missing a cat
Suzuki...four wheel jive!
98 coily...Camping rig.
Post Posted: Thu Jul 16, 2009 10:56 am
Transfer case or transmission lever hitting the tunnel?
Post Posted: Thu Jul 16, 2009 11:31 am
Does it happen when you shake the steering wheel back and forward while stopped? It could be the spring packs moving. Mine has just started doing that.... :roll:
Vehicle: '92 Sierra
Post Posted: Thu Jul 16, 2009 11:57 am
x2
What about your exhaust? Maybe you bent it on the trails and its sitting against the chassis/body. I've also had a similar noise when I first bought mine which was caused by missing rear body mount bolts
Post Posted: Thu Jul 16, 2009 5:07 pm
i had that sort of noise from destroyed shock bushes, i also had that sort of noise from a skipping transfer chain but thats just a stupid coily thing, um i had that sort of noise from a loose transfer case mount annd a busted gearbox mount aaand when my old orange car decided it didn't need the rhr shackle
Vehicle: SJ80
Post Posted: Thu Jul 16, 2009 6:10 pm
Had the leafpack niose before, and yes it was most noticable when sitting still and turning the wheel, think this might be different. May be something to do with the quality of the body lift i'm using. I've noticed one of the mounts is as tight as I can get it yet I can still just turn the urethane block by hand. Might have to remove that female bolt and shorten it slightly as it seems to be running out of thread before the block is fully clamped in there. Am not too worried about it now tho, it would seem it's all part and parcel of loving a sierra! Thanks for the input!
Bronson
Post Posted: Thu Jul 16, 2009 9:12 pm
i had the same issue noises on speeding up etc turnede out i have pushed my ehaust up and it was tapping on the body under the foot well could be it
Users browsing this forum: Susiethezook and 209 guests
