It is currently Thu Oct 22, 2026 5:04 pm
Post Posted: Sat Aug 01, 2009 5:23 pm
how do you get a stuck axel off? they have been out befor but this time she just doesnt wana come out
navara on 33s. hopfully rear air locker soon
Post Posted: Sat Aug 01, 2009 5:39 pm
im guessing it is the rear axle?
Use a slide hammer, if you dont have one get a piece of chain about 2ft long. Attach it to one of the studs in the break drum, use a wheel nut to hold it in place and give it a good pull.
Vehicle: MY2019 Jimny
Post Posted: Sat Aug 01, 2009 5:46 pm
Did you undo the brake backing plate?
Post Posted: Sat Aug 01, 2009 5:51 pm
yer im not stupid.
ive done what ridge said basicly almost tiped the car off the jacks!
Post Posted: Sat Aug 01, 2009 6:21 pm
get someone to hold force from the axle to the axle housing with a crow bar (tricky), and hit the end of the axle with a big hammer shocks them out
Post Posted: Sat Aug 01, 2009 7:03 pm
ol skool method. = some may not like this.. but I only do this on really stuck ones and when theres no slide hammer available.
Loosen all 5 wheel nuts to half out the thread... and undo everything.. and use the wheel with the tyre as a slide hammer.. by putting your boot on the leaf and yankin the tyre in and out until the bearing pops out.
works every time..
I dont really like doing that as it can damage the wheelnut threads, but Ive done it as last resort.
Tom
Post Posted: Sat Aug 01, 2009 10:31 pm
got it off. the reason it was so tight is because the spline on the axel is twisted! time for some after market ones i think.
i made up a bit of flat bar with 2 hole drilled in it and bolted it to the axel then used a BFH to wack it off
Users browsing this forum: No registered users and 123 guests
