It is currently Mon Oct 19, 2026 5:59 am
Vehicle: 87 Samurai
Post Posted: Wed Oct 09, 2019 12:26 am
Been doing some reading on Alignment specs, and how a vehicle with modded suspension can sometimes require different specs than the same vehicle that is unmolested and still has the original tire size. There is much alignment info and forum-chat out there for roadsters, race cars and such, and even some for [newer ] Jeeps and trucks, but very little for our Sj13 Samurai's. So......I'm trying to port the general theories of such, over to our zuk application.
Of interest, is the complex interplay between caster, tire diameter, mechanical-trail, camber, scrub radius and relative camber changes when making turns [ on road ], and how it effects the handling characteristics of our Samurai.
Tire diameter, caster angle [ and thus trail ], toe in / out, and scrub radius to a degree are all adjustable with swapping parts or adding wheel spacers or wheels with different widths and offsets. The Steering Axis Inclination [ SAI ] is not easily adjustable on the Samurai...…..having a solid axle, steering knuckles and king pins.
So my questions relate to, why we alter the caster angle after making a suspension mod, change to ride height, changing tire diameter, adding suspension up-travel, track width, etc, etc. What exactly are we wanting to achieve with alignment spec changes, post mods? In my mind, are we wanting to "get back to" or maintain the good road handling characteristics that may have been lost with said mods. This means.....no death wobble, correct return-to-center steering, appropriate negative / positive camber for cornering, correct toe in / out for straight-line stability and yet have decent "turn in" characteristics without wandering, light but not wandering steering, etc.
When we mod, we often go to a larger tire diameter. This mod alone changes the trail alignment spec, making it longer. For example.....going from a 205 / 75 / 15 tire to a 31" diameter tire almost doubles the trail length spec. Does this change alone, noticeably affect the handling / steering as discussed? Adding positive caster does the same thing....increase the trail length spec.
What is the significance of "trail"? Well, from what I understand, not enough trail makes for flighty, light steering that has a propensity for steering wander. Too much trail can initiate "death wobble" oscillations, and magnify any other component deficits that lean toward causing death wobble. Correct amount of trail will provide stable steering, good return to center, without causing death wobble or overly heavy steering. In theory anyway.
So what is the "correct" amount of trail for our Samurai's? Is it the amount that was originally engineered into the car, with a caster spec of 3.5 deg positive, and 205 / 75 / 15 tires?
By my calculations, oem trail is about .86 inches. Not sure if this is correct or not tho. I have not found the actual trail spec published, but rather had to use a calculator to try to figure it out;
https://www.rbracing-rsr.com/rakeandtrail.html
If trail spec is changed with tire diameter and caster angle......then the longer trail [ from larger tires ] can be brought back into spec by reducing caster angle.
IS this the whole point to a "correct" caster angle? to bring the trail into spec?
This is where it gets complex.....the interplay between caster angle, camber pos / neg in turns, scrub radius being a "magnifier" of characteristics, suspension up travel and how camber changes with compression, etc.
What are your thots on Trail spec, your caster angle, tire diameter and why you run the specs / settings that you do?
This is an interesting link showing the different specs between different cars.
http://www.car-engineer.com/suspension- ... -behavior/
Post Posted: Wed Oct 09, 2019 7:30 am
Suzukis have inadequate caster because they were designed with manual steering- less caster = lighter steering at low speed.
When converting to power steering adding more caster is desirable.
Vehicle: 87 Samurai
Post Posted: Thu Oct 10, 2019 1:18 am
Yes, I've read that in other forums from many other guys, and it holds true for many other older cars and trucks, not just our zuks.
Still looking for your thots.....
Do we adjust caster angle to achieve a desirable trail spec, or, is mechanical trail just a product of setting the caster angle?
I'm not considering caster angle as how it relates to pinon angle and driveshaft angle.....this topic is about steering and handling.
Caster talk is a funny topic...…… ask 10 different average wheeler enthusiasts what they set their 4x4's caster angle at, and you'll get 10 different answers, but nobody seems to know or divulge their rationale to back up their angle.
Vehicle: 87 Samurai
Post Posted: Tue Oct 22, 2019 2:33 am
Allrighty then......no sharp sticks here versed in steering dynamics...…...I'll try elsewhere.
Post Posted: Tue Oct 22, 2019 6:56 am
Let us know what you find out. I don’t think you’re going to find much- i.e trail is just a side effect of caster. I sort of think you’re implying that there is a correct number for trail and that caster might need to be adjusted to get trail into spec. I don’t think that’s the case because it implies as tyre size increases caster would have to be decreased. That’s undesirable. Let’s not forget that U4 cars, free from the constraints of mechanical steering (and therefore death wobble) run very high caster- 15deg or more.
Post Posted: Tue Oct 22, 2019 7:06 am
Most of us seem to like to keep it simple, rather than try to overthink the crap out of everything we look at ....
Suzukis, like most of the "cheaper" vehicles were designed as simple workhorses, rather than sophisticated performance machines. And that's just the way we like it.
Post Posted: Tue Oct 22, 2019 7:23 am
Speak for yourself :D but I agree that trying to reverse engineer a car to understand the finer nuances of steering theory is largely a waste on a leaf sprung Sierra. Brake and accelerate in 4wd and caster and trail go out the window.
The bigger concern is that misunderstanding a theory can result in counterproductive outcomes. Believing trail is an objective means a Sierra axle running 35’s would have almost no caster at all, and it doesn’t take much to understand that’s going to be terrible.
Post Posted: Wed Oct 23, 2019 5:57 am
Speak for yourself
I did say "most of us" :thefinger:
Vehicle: SJ413
Post Posted: Wed Oct 23, 2019 5:59 am
Eddy wrote:
Speak for yourself
Yeah, come on Steve! We all knew you were the exception to that haha
Vehicle: 87 Samurai
Post Posted: Mon Nov 04, 2019 2:27 am
Yes, caster angle is set to provide the correct trail for our cars, with tire size and all of the other suspension and steering characteristics calculated into the equation. Correct trail is THE reason, in fact, with pinion angle as a consideration, not withstanding, that we change / set caster angle. In other words...….trail is a product of caster angle.
Yes, in theory, larger tires require less trail than smaller tires, but with other considerations needed to achieve the best steering and handling characteristics, there is more to it than simply setting out to achieve xxx millimeters of trail. I'm guessing that you guys don't know, care, or have access to such knowledge, and neither do I, so I won't even ask, lol.
Post Posted: Mon Nov 04, 2019 6:14 am
I don’t consider pinion angle at all in relation to caster. If the pinion angle becomes impractical due to the required caster angle then the knuckles need to be cut and turned.
Do you express toe-in/toe out in mm or degrees? I think that’s an example of the the same thing you’re discussing here. The manual lists toe in both mm and degrees, but the mm figure is only relevant for stock tyres. We don’t make significant changes to toe when tyre diameter is changed and there’s no good reason to make significant changes to caster when we change tyre diameter either even though, like toe, changing tyre diameter changes the measured value in mm.
Users browsing this forum: Google [Bot] and 415 guests
