| PCV valve on G13 BA engine https://auszookers.com/forum/viewtopic.php?f=5&t=56237 |
| Author: | Eric.Kennedy0 [ Mon Jan 13, 2020 1:27 pm ] |
| Post subject: | PCV valve on G13 BA engine |
Hi there Suzuki lovers. I wonder if anyone could possibly tell be where the PCV valve is on a G13 BA engine, and how to extract it. I suspect it is on the block. It certainly isn't on the rocker cover. I have a 1993 Holden Barina 5 door 1.3 manual ( re-badged Swift). Many Thanks Eric |
| Author: | bumstein [ Mon Jan 13, 2020 3:22 pm ] |
its in the top of the intake manifold right next to the rocker cover. It’s the thing that sticks upward with a T piece and hoses running to the rocker cover and airbox Pretty sure it’s threaded so should screw out And welcome to AZ!! Edit: sorry I’ve just reread your post and yours is a Barina, I was thinking Sierra. I’ll try find out |
| Author: | bumstein [ Mon Jan 13, 2020 3:31 pm ] |
| Post subject: | Re: PCV valve on G13 BA engine |
Not sure sorry. It should look like this anyhow
| Author: | fordem [ Mon Jan 13, 2020 10:26 pm ] |
![]() This is the part number called out for the 93 Swift SOHC engine and it should be exactly where bumstein said it would be - find the hose from the rocker cover to the air filter housing, follow the tee to the intake - as far as I recall it doesn't screw in, but is held down be a plate with two screws |
