Vehicle: Sierra SJ410
Posted: Wed Jan 22, 2020 7:15 pm
Hi. I am now at the stage of re-furbishing the exhaust. The old exhaust is well past its use by date. What are the 2 mufflers? Is the front one a catalytic converter? The Sierra is a 1981 1.0 litre. Toying with putting a set of extractors on it. They are 2" exit pipe size, which I will reduce down to 40mm. Alternatively megazip still sells complete exhausts. Regards Alan
Posted: Tue Jan 28, 2020 1:44 pm
Hi again. Would someone with an early model sierra (mine is an 81) be able to measure the distance from the round cross bar on the rear chassis to the top of the exhaust pipe. My original exhaust pipe at that section was a bit of water pipe that looked like it had been bent around a fence post. Regards Alan
Users browsing this forum: No registered users and 214 guests
