Joined: Sun Jan 29, 2017 8:36 am Posts: 75 Location: Kallangur North Brisbane
Vehicle: Suzuki Jimny 2010
Posted: Thu Jan 30, 2020 10:31 pm
Hi,
Planning on an M18 upgrade in my Jimny, with motor from Liana. Apparently the pressure/clutch plate is larger in the Liana. Can anyone tell me if it will fit in the bellhousing of 2010 model Jimny?
I intend to have the flywheel machined so re-drilling to suit the Liana pressure plate is no problem.
Thanks
_________________ '10 Jimny, M18A, 80mm lift kit, 215/75R15 on ROH mags, rear disk brake conversion and front disk vented upgrades. Air Lockers front and rear; cruise control; 70L fuel tank. Castor corrected Radius Arms, rear panhard rod raised mount, steering damper; bash plates transfer, radius arm, shocks, dual batts, headers, winch, rock sliders, custom aluminium roof rack on fitted tracks, Atoto head unit, LED headlts & HID 7" driving lights; 105Amp alternator to feed all the lights.
Users browsing this forum: No registered users and 395 guests
