| Airlocker stuck ON ??? https://auszookers.com/forum/viewtopic.php?f=5&t=56459 |
| Author: | alien [ Thu Jun 04, 2020 5:58 pm ] |
| Post subject: | Airlocker stuck ON ??? |
Anyone experienced this before?? In the wet weather last week I was having some slippy fun times with the locker on. Disengaged it before reversing up my driveway, and then the other day went for a spin and it's still locked. I have: - Undone the solenoid - Cleaned the brass filter - Turned it off and on MANY times - Undone both fittings on the diff in case there's a blockage there (there wasn't) - Done all sorts of figure 8's and throttle blips Any ideas how to get it to unlock??? lol |
| Author: | fordem [ Thu Jun 04, 2020 11:23 pm ] |
| Post subject: | Re: Airlocker stuck ON ??? |
Have you tried jacking the car off the ground? If there's any wind up on the axle the locker might bind and not move until the stress is released. |
| Author: | alien [ Fri Jun 05, 2020 6:26 am ] |
Never even crossed my mind - I'll give it a crack and report back =) |
| Author: | alien [ Fri Jun 05, 2020 8:01 am ] |
No effect... Went back and forth a bunch, jolting it and moving it gently and still locked. |
| Author: | Reubs [ Wed Jun 10, 2020 3:55 pm ] |
Older style locker - broken tabs on the plastic piston inside the locker? |
| Author: | atari4x4 [ Wed Jun 10, 2020 7:22 pm ] |
Reubs wrote: Older style locker - broken tabs on the plastic piston inside the locker? This 100%, happened to mine. Permanently locked on when it happened. |
| Author: | alien [ Wed Jun 10, 2020 8:17 pm ] |
Booooo.. Maybe Advice I've been given from an ARB fitter is to try blow out the metal tube in the housing and see if that frees it up as it might be full of oil... He's seen that happen a bit apparently. Assuming if it's the plastic tabs, the whole centre has to come out? |
| Author: | atari4x4 [ Wed Jun 10, 2020 9:26 pm ] |
Yes, diff out. Not even sure if you can still get the piston |
| Author: | tanshi [ Thu Jun 11, 2020 7:56 am ] |
had it happen a few times, we looked at making alloy pistons to replace |
| Author: | alien [ Thu Jun 11, 2020 12:44 pm ] |
@tanshi - did you ever do it? The plastic ones are still available according to ARB, but if I can future-proof it with alloy that'd be awesome. Though, the current rear locker is from 2008 so it has done rather well haha |
| Author: | tanshi [ Thu Jun 11, 2020 1:49 pm ] |
nah we never finished it. they would be friken expensive to make from billet. |
| Author: | alien [ Thu Jun 11, 2020 7:53 pm ] |
Oh right, yeah I suppose that'd be the only way??! it'll be interesting if the replacement plastic part is made any differently to the old one. |
