| 1987 Sierra leans to Drivers side https://auszookers.com/forum/viewtopic.php?f=5&t=56485 |
| Author: | Spry-G [ Sat Jun 20, 2020 6:31 pm ] |
| Post subject: | 1987 Sierra leans to Drivers side |
Gday lads and chicks Got a 87 tin top I am doing up for the road, mainly gonna be a shooting rig. So I went for a roady and got knocked back for the aggressive lean to the drivers side, I put brand new springs in to try fix the issue and I had no luck, they won’t pass it on the roady until it’s sorted so I’m stuck for what it could be, yes I know they lean a little bit but shouldn’t be leaning this bad. Any help is appreciated. Cheers lads |
| Author: | fordem [ Sat Jun 20, 2020 11:42 pm ] |
| Post subject: | Re: 1987 Sierra leans to Drivers side |
Did you put the correct springs on the correct side? It's not unusual for driver side & passenger side springs to be different and the longer spring is usually fitted on the driver's side - you also need to look for possible frame, axle or other suspension related problems. |
| Author: | Gwagensteve [ Tue Jun 30, 2020 2:23 pm ] |
If swapping the springs from side to side doesn't do it, remove a leaf from the passenger side. |
