Posted: Wed Jul 01, 2020 6:23 pm
I have been doing a bit of looking and testing to find the part numbers of a few of the Jimnys plugs, in order to make piggyback harnesses and avoid cutting into the Cars wiring to fit lights etc.
Headlights are Sumitomo 6189-0323 6188-0175, High beam is the middle wire in the latch side and is positive switch, yes after years of people finally getting to understand negative switched, its turning around again lol The dash switches are 6098-3810 6098-3802 This lets you tap into the dash lights, they are turned on and off on the positive side, but dimmed on the negative side, so you need a switch that can cope with that The plug in the back of the headunit that has reverse and parkers and handbrake is Yazaki 7283-5830 and 7282-5830 Easiest way to tap in a signal for reverse lights if you plan on a switch and relay Green plug that fits the reverse camera spot in the stock headunit is JAE Electronics IL-AG5-5S-S3C1 and IL-AG5-5P-S3C1, is also the plug that fits the push button Prado switches that fits the dash spots
Users browsing this forum: No registered users and 400 guests
