Hi all I've got a 2019 Suzuki Jimny in Automatic. Since I purchased the car there has been a whining noise during acceleration and deceleration (see video). Haven't brought it up with the dealer as I assumed it was normal however I've seen comments on a Jimny Facebook page recently which seems to suggest otherwise. Is this normal? or do I need to get it looked at? It's been serviced twice and has never been brought up by the dealer. Any advice would be appreciated. Cheers
Transfer case is chain drive so there shouldn't be any gear to gear contact (which is what that sounds like) but regardless, that's an unacceptable amount of noise for a new car.
It can be difficult to get dealers to be responsive to noises, you'll have to be quite persistent.
Vehicle: 91 Tin Top
Posted: Sun Jul 12, 2020 4:05 pm
When I installed the low range reduction gears into my push button Jimny transfer case the gear to gear contact was considerably louder then the standard gears.
It actually sounded very similar to that video....
Vehicle: 91 Tin Top
Posted: Sun Jul 12, 2020 5:58 pm
Only in low. Even though they where a good Japanese brand reduction gears, I just assumed the aftermarket gears didn’t have the same ‘finish’ on the cut as the factory ones.
I was going to ask the OP if that video was taken driving in low range.
Posted: Sun Jul 12, 2020 6:11 pm
Did it have the diff oils changed at the 10k service? I dont know why its in the book but I assume they know there is early wear in the diffs that needs new oil.
Mine makes a similar pitch and sound whine when driving, sometimes I think its a bit whiny then remember thats how they have always been, its hard to say if yours is louder or not obviously, maybe you might be able to find a ride in another to compare?
And sadly, it does seem Suzuki Aus and the dealers still havent got any good at dealing with stuff like this.
Yep. Front and rear diff oils changed at 10k service according to invoice.
Haven't had the chance to the drive any others. Have seen videos but hard to tell how how loud it is for comparison. Spoken to another owner who brought it up with their dealer - answer was its normal operation and is due to a combination of transfer case not having a 'true neutral', transfer case being located close to driver and lack of sound deadening.
Thats my worry given my lack of mechanical knowledge - just a 'thats what they all sound like' - and then something goes wrong down the line which could've been prevented.
Gwagensteve as usual is right
I'm an owner of JB74 MY2019 manual. My noise is more severe and short, occurring only in first gear at around 1600rpm when taking off up the hill. Took some time to convince the dealer, but new chain was order from Japan and replaced early this year. Was great afterwords for 4 months, but now the problem is back to what is used to be. Will notify the dealer on next service.
Other found problems: Seized starter motor puley after driving through a shallow water puddle, car was thoroghly washed that same day. Anfter long debate with the dealer they aggreed to fix it free of charge. Rare loud cracking noise apparently comming from rear axle, only on off road. Didn't happened again for last six months
This is standard practice for the dealer network - They will attempt to deny any warranty claim if there is evidence the vehicle has been operated off road. Damage due to water and mud is a difficult one because of where the factory set fording depth. It's not by accident this is generally in the owners manual, and it's often hilariously low (like bottom of the rim) - it's so warranty can be denied on vehicles which are water damaged. There is good reason for this - water/mud damage is extremely expensive to repair, can be widespread, and might only show after some time after the incident. Dealers can't be expected to be forensic experts and make a call on how deep the water/mud was or how the owner used the car.
This was completely normal for the old model jimny. As the new model runs basically the same suspension components I'm not surprised it's still present. I believe it's movement in the springs on the seats - they come slightly out of their seat and then creak/clack as they sit back on the seat.
Soon will go for another round with the dealer , asking to repair transfer case chain noise. Now this fastidious noise occurs almost every time in 1st gear, hill or flat plus you can sort of hear it in 2nd too. Does some one know if new Jimny engine can tolerate E10 ?
Hi just raising questions regarding this . The video link doesn't work so I can't copmare. Daughters 2023 automatic Jimny makes a Shimmering noise rather than a rattle when she takes off. Its not always there and happens in High and Low range . Its been suggested it could be the timing chain as mentioned here .She has mentioned it at services but of course they can't hear it . Is the rattle as the OP described an obvious chain rattle ? The shimmering I'm hearing may be something else.
I have no idea what a "shimmering" noise is, and I don't see the OP describing a rattle, he mentions a "whine". You say it's been suggested it could be the timing chain "as mentioned here", maybe I missed it, but I don't see any mention of timing chains here, other than in your post. It should be fairly easy to differentiate between a transfer case chain noise and a timing chain noise, the timing chain noise will usually be present with the vehicle stationary. Maybe you could post your own video so we know what your noise sounds like.
The transfer case on the fourth gen Jimnys has a characteristic graunch or grunt that occurs in first gear at around 2000 rpm, you're unlikely to hear it with an automatic transmission , and whether or not you hear it with a manual transmission will depend on how smartly you pull away, I can replicate it will by rocking on & off the throttle in first on my three door. The noise is apparently caused by the timing chain "vibrating" under tension and I suspect there is a resonance effect related to the engine vibration at 2000 rpm. It's not as noticeable with the automatics because of the "cushioning effect" of the torque converter.
I can see your confusion as I made a few mistakes. The shimmering noise could be the same as the whine description but I don't have access to the video to compare. The thing is there is a noise how ever you want to describe it. My mistake saying "timing chain" when I meant transfer case chain . ( you also made the same mistake in your post ). So it appears you can hear a noise in the automatics which has been suggested by other jimny owners that it is the transfer case chain.
Users browsing this forum: No registered users and 275 guests
