| Super Carry sk410 Timing and Ignition coil wiring. https://auszookers.com/forum/viewtopic.php?f=5&t=56534 |
| Author: | pigdog_ [ Mon Jul 27, 2020 8:32 pm ] |
| Post subject: | Super Carry sk410 Timing and Ignition coil wiring. |
Hello all, I'm trying to get my carry started after having to take the distributor off to replace a gasket. I don't have a manual for my engine, an f10a (1988 Suzuki Super Carry sk410). Now from my research, I think the timing is 8 BDTC but I want to know what people are running. I also want to know the wiring for the ignition coil, I took it out to test with a voltmeter (The ballast resistor died) and now I'm not exactly sure how it should be wired back in (Should have taken photos) as I can't find the exact diagram for my engine. Thank you! |
| Author: | Gwagensteve [ Mon Jul 27, 2020 10:05 pm ] |
| Post subject: | Re: Super Carry sk410 Timing and Ignition coil wiring. |
Never mind about 8 BTDC, it would probably start +/- 30 BTDC, so something is very wrong. Can’t help with wiring, but do you know you have spark? |
| Author: | pigdog_ [ Tue Jul 28, 2020 4:46 am ] |
Gwagensteve wrote: Never mind about 8 BTDC, it would probably start +/- 30 BTDC, so something is very wrong. Can’t help with wiring, but do you know you have spark? Managed to get a spark out of the coil last night but still dead when I turn it over |
| Author: | fordem [ Tue Jul 28, 2020 8:44 pm ] |
![]() The above image is taken from a Mini site, but is a typical points style ignition system, with a ballast resistor. Are you getting spark at the plugs? |
