I picked up my first SQ625 last weekend. Using the fluid specs I found in the Suzuki WSM I've started replacing them all. All, until I got to the trans.. WSM states DexIII but the actual drain plug on trans is stamped with T-IV. I know the Aisin transmissions in Toyotas are quite picky about only using T-IV. Should I be running it in this one too?
Users browsing this forum: Google [Bot] and 230 guests
