It is currently Mon Oct 19, 2026 5:08 am
Vehicle: 97 SJ80
Post Posted: Thu Oct 08, 2020 11:48 am
Hey folks,
Anyone know if an SJ80 coily body is a direct fit onto a leaf sprung sierra chassis?
Even with the difference in styling maybe they kept the body mount locations and gearbox tunnel holes etc all the same between models? :)
The only difference in body besides styling may be the holes to access the top of the front shocks? Or is that the same with the leaf sprung models... I only have messed around with an SJ80.
Cheers!
Post Posted: Thu Oct 08, 2020 3:12 pm
Yes has been done all body mounts are the same.
Vehicle: 97 SJ80
Post Posted: Thu Oct 08, 2020 3:30 pm
That's good news! I read something about seatbelt bolt holes being different between models. Was this only between the early 1980's zooks and the later 1990's ones?
I have an SJ80 body that is ok'ish (depends on your perspective!) that I might fix up and put on a leafy chassis - if I can't find a leaf sprung sierra to buy...
Post Posted: Sat Oct 10, 2020 9:28 am
Seatbelt bolt holes aren't relevant as they have nothing to do with the chassis. Yes, there were changes in seatbelt mounts over the years, most notably between NT and WT when inertia reel belts became standard. I recall the SJ80 buckle is on the seat rail, not the floor, but again, that has nothing to do with the chassis.
Unless you're starting a ground-up build, you'll really want to use an SJ70 chassis as the axle width is closer to the SJ80, and the body mounts are compatible.
Yes, the coil sierra has different inner front guards to clear the top of the shocks. That won't matter with the leaf sprung chassis.
Vehicle: 97 SJ80
Post Posted: Sun Oct 11, 2020 7:47 pm
Thanks!
I bought a SJ70 chassis for $50. So the build up can begin once I strip it and then run it into the sandblasters.
On a side note: what's the best chassis paint people are using in OZ? I want something super anti-corrosion...
Vehicle: 97 SJ80
Post Posted: Thu Oct 22, 2020 5:32 pm
Will an SJ80 body fit a narrowtrack ('86) chassis? Are the body mounts the same also?
Thanks
Post Posted: Thu Oct 22, 2020 7:08 pm
Yes, so long as the car is an Sj50 (1.3 litre)
Vehicle: 97 SJ80
Post Posted: Fri Oct 23, 2020 9:42 pm
Thanks! Are the leaf springs the same between narrow and widetrack? I searched around and apparently the springs are mounted differently, but perhaps the actual spring packs are the same?
Post Posted: Sat Oct 24, 2020 1:26 pm
Same springs and shackles. Its just the mounts that are different.
Vehicle: 97 SJ80
Post Posted: Mon Oct 26, 2020 8:40 pm
Thanks!
Do headers made for the 1.3L in the 88-95 samurais fit the SJ80 coilys? Same clearance down the side of engine etc?
It seems every stainless header I look at is made for the 88-95 body...
Post Posted: Tue Oct 27, 2020 5:24 am
Leafy and coily extractors are different
Post Posted: Tue Oct 27, 2020 5:32 am
Due to tie rod clearance.
Vehicle: 97 SJ80
Post Posted: Tue Oct 27, 2020 8:50 am
Okey doke. I think I get it.
If it is due to tie rod clearance - not engine mounts/body... If I am running a leafy chassis and coily body - I will need leafy extractors (88-95)?
Can't wait to build this engine!
Post Posted: Tue Oct 27, 2020 11:34 am
Correct.
Users browsing this forum: No registered users and 233 guests
