It is currently Sun Oct 18, 2026 10:34 pm
Post Posted: Wed Oct 14, 2020 12:12 pm
Emission Control Light came on about 600ks from closest Suzuki dealer. What should I do?
Post Posted: Wed Oct 14, 2020 1:17 pm
There’s a specific emission light or do you mean the check engine light?
Is it running OK?
Try turning it off and disconnecting the battery for a while, reconnect and drive again, note when the light comes back on.
If it’s the CEL and you can get access to a service manual, (online)the 2011 cars may still have a diagnostic plug (this is NOT the OBDII port)- there is a procedure to jump two pins which will put the CEL into diagnostic mode. The light will then flash a code which will tell you what is wrong.
Post Posted: Thu Oct 15, 2020 12:10 pm
Thank you! The car lost power and wouldn't't go over 70ks.
I will relate your message to a retired mechanic friend of mine here in White Cliffs.
Users browsing this forum: No registered users and 255 guests
