| Sierra head on gti bottom end https://auszookers.com/forum/viewtopic.php?f=5&t=56734 |
| Author: | MrRocky [ Sat Oct 31, 2020 3:17 pm ] |
| Post subject: | Sierra head on gti bottom end |
Ive been given a bare gti engine with no wiring/manifolds ect... Just curious if i can pop a sierra head on there as my lwb engine has done 315,000kms now and i figure it might pay to have a backup ready. I know the gti has 4 valve notches out of the pistons to account for the 16v head. My question is will the 8v sierra head valves line up on the gti piston crown ok ? If they dont has anyone used a die grinder or the like to take some meat out of the gti piston to make it work ? Cheers |
| Author: | alien [ Sat Oct 31, 2020 6:20 pm ] |
| Post subject: | Re: Sierra head on gti bottom end |
What about a BB jimny head? They're already 16v and you can buy them brand new (ask me how I know lol) |
| Author: | MrRocky [ Sat Oct 31, 2020 7:27 pm ] |
BB head is same as baleno Perhaps if i could find a dead jimny bb motor Pretty happy with the 4k carb setup wasnt really planning on going injection |
| Author: | Gwagensteve [ Sun Nov 01, 2020 7:12 am ] |
I'd say sell the GTi long block to a ricer and use the funds to buy a G16 or something that will work. It sounds like the end result will be an interference motor with unknown compression ratio. alternatively, put carbs on the GTi. |
| Author: | MrRocky [ Sun Nov 01, 2020 10:22 am ] |
Might just rebuild it with some new pistons and see if i can work around the different gudgeon pin setup to sierras |
| Author: | fordem [ Sun Nov 01, 2020 10:58 am ] |
Rather than mess around with the pins, you should be able to swap the rods. When I did the 8v engine in my Swift, I swapped the crank out for a GTI crank, just because it was available and forged. |
| Author: | MrRocky [ Sun Nov 01, 2020 5:06 pm ] |
Will the bike carbs work on a mk2 motor without ecu ect... Dizzy should take care of the spark on its own ??? |
| Author: | vet 180 [ Mon Nov 02, 2020 10:46 am ] |
Gwagensteve wrote: I'd say sell the GTi long block to a ricer and use the funds to buy a G16 or something that will work. I am with this.It sounds like the end result will be an interference motor with unknown compression ratio. alternatively, put carbs on the GTi. You will not need the benifits that a gti block and head provide so sell on to someone who does Sent from my SM-N960N using Tapatalk |
| Author: | fordem [ Mon Nov 02, 2020 7:58 pm ] |
MrRocky wrote: Dizzy should take care of the spark on its own ??? If I recall correctly, no, it's not a self contained ignition system, timing advance is handled by the ECU - the distributor just handles the cam sensor and distributes the spark. |
