It is currently Mon Oct 19, 2026 8:23 am
Vehicle: Suzuki sierra SJ413
Post Posted: Fri Dec 04, 2020 4:05 pm
Hi all, since I've recently put the bigger tryes on I've had death wobbles and would swerve off the road... I've gotten 2 wheel allingments, steering dampener put on, off-set bushes to correct the diff rotation, and is still bad.. any one had this problem before? And found a solution? Mechanic will be string lining the car tomorrow to see if the chassis etc are bent or not.
Any help would be appreciated cheers.
Post Posted: Fri Dec 04, 2020 4:33 pm
#1 is kingpin bearing preload (set it to the upper limit) and knuckle wiper seals. As it’s a coil sierra, also panhard bushes and chassis end radius arm bushes. Chassis end radius arm bushes are a factory fix for wobbling jimnys.
Post Posted: Wed Dec 09, 2020 7:29 am
Cheers mate, will have a look.
Users browsing this forum: No registered users and 223 guests
