| Author |
Message |
letsbebad
Vehicle: 2004 Suzuki grand vitara
 Posted: Sat Jan 09, 2021 8:34 am |
i’m new to the site i thank the admin for letting me in what i’ve got is a 2004 Suzuki Grand Vitara 2.5 V6 and my daughter was driving it home from work in the rain she pulled over as the front plastic inner guard fell down turned the car off now when she went to leave the car wouldn’t start had to get it towed 240000km’s on the clock ive replaced the fuel pump and cam/crank angle sensor behind the L/H head it winds over no start and the engine management light dosen’t show up on the dash two things i think it might be ecu or engine immobiliser any help would be good thanks Rod
fordem
Joined: Mon Apr 19, 2010 11:30 pm Posts: 2658 Location: Georgetown, Guyana
 Posted: Sun Jan 10, 2021 5:05 am |
First - do the "normal" dash lights (oil pressure & charge) come on when the key is turned to on? If not, find out why. Second - if the "normal" dash lights come on, and the check engine light does not - find out why - start with the bulb, and then the power to the ECU.
If it's an immobilizer fault, there should be a warning light of some sort and a check engine code as well.
ZUZUKI
Joined: Thu Sep 02, 2010 5:50 am Posts: 427 Location: Melbourne
 Posted: Sun Jan 10, 2021 9:42 pm |
Have you checked the air cleaner element for water?. The air intake is behind the R/H/F inner wheelarch liner - if that is the bit that fell down & water got into & past the air cleaner element, it can be enough to put the fire out in the cylinders. At cranking speed, water remains in the cylinders. Take the spark plugs out to see if they are wet. If so, leave them out & tow the car down the road in gear (if a manual) to turn the engine over faster to get the last of the water out, refit plugs & hope no damage was done. Rgs, Michael
fordem
 Posted: Sun Jan 10, 2021 9:55 pm |
Just my $0.02 - you're not going to get water in the engine from driving in the rain - the intake on the 2.5 is above the wheel, at least 75cm above the road surface.
letsbebad
 Posted: Mon Jan 11, 2021 7:43 pm |
well i pulled the cover off the ECU and it is badly water damaged now ive got to source another ECU 33920-52J41 going into G/V 2004 2.5 V6 manual i’m on Bribie Island nth of Brisbane any ideas would be good thanks
fordem
 Posted: Tue Jan 12, 2021 2:29 am |
Serious question - have you tried washing it out (use isopropyl alcohol) and letting it dry?
letsbebad
 Posted: Tue Jan 12, 2021 9:55 am |
yes it has fried part of the board in the ECU got to try and source another one
losfer
 Posted: Wed Jan 13, 2021 10:45 am |
Dont like your chances of finding that ecu and they are a couple of grand new , but good luck.
_________________ Dr Suzuki - South east Queenslands most experienced mobile Suzuki mechanic. Please like and share my facebook page - www.facebook.com/suzukimechanic
30ONA
 Posted: Wed Jan 13, 2021 11:41 am |
losfer wrote: Dont like your chances of finding that ecu and they are a couple of grand new , but good luck. Well I was going to suggest Dr Suzuki but too slow. I had success with James in the UK from rhino power. It wasn't a quick process but only cost me a few hundred in the end. You'll probably need to send the ecu, key and immobiliser module.
letsbebad
 Posted: Wed Jan 13, 2021 4:23 pm |
can another ECU number be used i can find ones starting with 33920 it’s the other numbers that are out thanks for your help guys
losfer
 Posted: Wed Jan 13, 2021 5:25 pm |
I could probably get it repaired but you could be looking at up to $650 providing it can be repaired.
30ONA
 Posted: Wed Jan 13, 2021 6:02 pm |
fordem
 Posted: Wed Jan 13, 2021 10:48 pm |
letsbebad wrote: can another ECU number be used i can find ones starting with 33920 it’s the other numbers that are out thanks for your help guys 33920 is what identifies the part as an ECU, 99% of the Suzuki ECUs start with 33920, the 52J41 tells you which vehicle - in this case an Australian market SQ625-3 with manual transmission.
Rhodest
Vehicle: 05 grand vitara v6 2.5l pre fl
 Posted: Tue Feb 15, 2022 7:28 am |
Are there any ECUS out there... 33920_52J41 specifically?
Brenno
Joined: Thu Apr 22, 2010 11:30 pm Posts: 1000 Location: Hobart
 Posted: Wed Feb 16, 2022 5:14 am |
Message suzukitas. He might
