It is currently Sun Oct 18, 2026 1:50 pm
Vehicle: 1995 Vitara, SWB
Post Posted: Sun Jun 02, 2024 3:05 pm
Hi all.
For a period of time the the 16b has had a low idle issue, but this was not all the time. Lately it has become worse and now stalls when not under acceleration. After heaps of reading and checking, it looks like the issue is a carboned up Throttle body.
I have now removed the throttle body, and, as expected it was certainly in need of a good clean.
Now to my problem where I am in need of some advice. Is it possible to remove the Idle Control Screw completely from the TB to clean the seat, or is it designed just to be loosened and then readjusted down to the proper setting.
I have attempted to remove it but it just spins on the threads when almost out.
Cheers and thanks in anticipation of your responses.
Post Posted: Mon Jun 03, 2024 9:43 pm
I thought ... "yep I got this!"
Strutted over to the bookshelf to pull out the workshop manual ... Not there! WTF?
So ... sorry, can't help unless the book shows up sometime soon
Post Posted: Tue Jun 04, 2024 9:50 am
Thanks for the reply Eddy. Much appreciated. Hopefully you locate that Manual :). Fingers crossed.
Post Posted: Tue Jun 04, 2024 3:44 pm
The Air bleed screw has an o ring on it which is why it isnt coming out. I wouldnt bother about removing it just give the throttle body a good soak in cleaner.
Dr Suzuki - South east Queenslands most experienced mobile Suzuki mechanic.
Please like and share my facebook page - www.facebook.com/suzukimechanic
Post Posted: Fri Jun 07, 2024 9:36 am
Thank you losfer. Thought as much, but just needed confirmation. Will give it an extra good soak with the screw wound out.
Users browsing this forum: Google [Bot] and 304 guests
