| LJ80 diff centers into LJ50housings. https://auszookers.com/forum/viewtopic.php?f=5&t=57779 |
| Author: | davidraeburn [ Tue Oct 29, 2024 2:20 pm ] |
| Post subject: | LJ80 diff centers into LJ50housings. |
I am fitting a LJ80 motor to a lj50 for a friend and I was wondering if the LJ80 diff centers will fit in the LJ50 housing to give a higher ratio for the 4 stroke motor also are the splines the same. |
| Author: | UBZ [ Thu Oct 31, 2024 4:16 pm ] |
| Post subject: | Re: LJ80 diff centers into LJ50housings. |
The diff head will bolt straight in , however the rear axles on the LJ80-II are larger , so the LJ50 axles likely won’t match the lJ80 centres. Pretty sure the front has a similar issue . I know you can fit LJ80 spider gears into lJ50 centre carriers to run 4.88 ratio diff in a Lj80 so would assume you could fit Lj50 spider gears into a lJ80 centre carrier to run the 4.55 ratio diff in a lJ50 Personally I would just fit bigger tyres on the LJ50 to account for the slight gearbox ratio differences . |
| Author: | davidraeburn [ Thu Oct 31, 2024 7:04 pm ] |
Thanks for the info I appreciate the help. |
| Author: | Gwagensteve [ Fri Nov 01, 2024 6:09 am ] |
My understanding is LJ50 is 22 spline front and rear and lj80 II (marketed here as the stockman) is 22 spline front 26 spline rear same as sierra. |
