It is currently Sun Oct 18, 2026 2:44 pm
Vehicle: 75 Cruiser
Post Posted: Fri Jun 23, 2006 11:03 am
Just saw something about this again and remembered i have a set of 1L gears which are used.
I've had some explanations from a few people but always got confused :oops:
Do you need 1 standard 1.3L transfer and these gears pictured? or do you need more bits from other cases to make a S1 transfer case?
Post Posted: Fri Jun 23, 2006 11:37 am
you need a set of late 1 litre gears, a 1.3 flange needs to be able to be fitted to that spline bit
then you get the gear that has the 2 gears as one and cut it in half and join the 2 bits from both gearsets together, if you compare to some 1.3 gears youll see how it would work
Post Posted: Fri Jun 23, 2006 1:43 pm
http://global.level1.com/products1.php?Id=10
thats a pretty good link to how it works
Vehicle: 75 Cruiser
Post Posted: Fri Jun 23, 2006 4:22 pm
yeah? i dunno, looks like a bunch of routers to me :?
Post Posted: Fri Jun 23, 2006 4:32 pm
:oops:
http://ironbark.bendigo.latrobe.edu.au/~jeff/xfer2.htm
Vehicle: 75 Cruiser
Post Posted: Fri Jun 23, 2006 4:38 pm
cool :)
Post Posted: Sat Jul 08, 2006 12:35 am
i want this lobster
[img]http://www.nbs4x4club.com/forum/files/thumbs/
Post Posted: Sat Aug 05, 2006 11:01 pm
i was looking at doing this, still considering it, only problem i've got is trying to figure out whether the modified idler gear set will be strong enough to not break when using it...
Users browsing this forum: Google [Bot] and 222 guests
