| What rims do I need https://auszookers.com/forum/viewtopic.php?f=5&t=5822 |
| Author: | Damo [ Sun Aug 02, 2009 11:49 am ] |
| Post subject: | What rims do I need |
I want to go to a 235/85R16 tyre but am a little unsure what rim to go with. I think a 16x7 with -15 offset is going to fit, what do you guys think? |
| Author: | Scrawny [ Sun Aug 02, 2009 2:51 pm ] |
| Post subject: | Re: What rims do I need |
Yeah, 7" is about right. Not sure on the offset though. Yours is just standard WT isn't it? Spring spacing etc? |
| Author: | Damo [ Sun Aug 02, 2009 3:38 pm ] |
ScrawnC wrote: Yeah, 7" is about right. Not sure on the offset though. Yours is just standard WT isn't it? Spring spacing etc?
Yeah std widetrack. If I could get a hold of a GV rim I would test that, I know the offset probably wouldn't work but I have some 1" spacers I could try it with. I should be able to get a pretty good idea of the offset that will work from that. |
| Author: | CairnsZook [ Sun Aug 02, 2009 3:58 pm ] |
I've been thinking about this too Damo - a tall skinny tyre with the right offset would eliminate any issues with rubbing on the springs. Federal make the Couragia in this size. I'm happy with my 29's I wouldn't hesitate to try them in a 33". http://www.federaltyres.com.au/specs/couragiamt.pdf Silverstone also do the Extreme in this size. I don't know if they are available in Australia though. http://www.silverstone.com.my/#1249176059738 |
| Author: | Damo [ Sun Aug 02, 2009 5:01 pm ] |
CairnsZook wrote: I've been thinking about this too Damo - a tall skinny tyre with the right offset would eliminate any issues with rubbing on the springs. It would make it easier to fit in there than a tall fat tyre that's for sure. The main reason I was looking at the skinnier sizes was that in my experience a 9" wide tyre seems to drive a lot better than a 10" tyre (on a Sierra that is). I'd say that skinnier tyres would put less stress on the drivetrain and take less power to turn too. Hopefully lighter too, all else being equal. CairnsZook wrote: Federal make the Couragia in this size. I'm happy with my 29's I wouldn't hesitate to try them in a 33". They are on my short list. I can get the 235/85 for about $230 a piece. 265/75 is the same height but about an inch wider if you're looking for something fatter. CairnsZook wrote: Silverstone also do the Extreme in this size. I don't know if they are available in Australia though.
http://www.silverstone.com.my/#1249176059738 Apparantly they are not available at the moment. |
| Author: | TZAR [ Mon Aug 03, 2009 1:09 am ] |
There is always a 33x9.50R15 AT BFG or 33x10.50R15 AT/MT BFG |
| Author: | Damo [ Mon Aug 03, 2009 10:43 am ] |
TZAR wrote: There is always a 33x9.50R15 AT BFG or 33x10.50R15 AT/MT BFG
33x9s might be OK if they still did them in a MT. Prolly too expensive for me anyway i'd say. |
| Author: | Gwagensteve [ Tue Aug 04, 2009 4:00 am ] |
I think you're on the money on all counts. The couragia's should be sweet in 235. I'd avoid the 265 - it undoes most of the advantage of the narrowness - it's near enough 10.5 wide. Steve. |
| Author: | Damo [ Tue Aug 04, 2009 11:49 am ] |
I still need rims!!! I'm pretty sure i'm going to have to go new, but it would be nice to find something other than a normal 'ole Sunraysia looking thing. |
| Author: | kenn [ Wed Aug 05, 2009 11:39 am ] |
Go have a look at the Procomp web site , they have some good stuff at good prices. |
| Author: | Damo [ Wed Aug 05, 2009 3:16 pm ] |
kenn wrote: Go have a look at the Procomp web site , they have some good stuff at good prices.
Thanks Kenn, I was actually checkin out Procomp last night Is that where you got your alloys from? They look nice! |
| Author: | RIKSTR [ Wed Aug 05, 2009 7:22 pm ] |
A steel GV rim will hang out and need a 1" flare on a Sierra, should be spot on |
| Author: | Damo [ Wed Aug 05, 2009 9:10 pm ] |
Thanks Rik, i'll have to see if I can get a GV rim to test with. |
| Author: | kenn [ Wed Aug 05, 2009 9:49 pm ] |
Yep, and they have the most offset I could find in that size ( 16") and style.. |
