It is currently Tue Oct 20, 2026 5:02 pm
Vehicle: Clown Car..
Post Posted: Sun Aug 02, 2009 4:26 pm
So im thinkin its time to renew the brakes.. if im in reverse and put the brakes on I can hear and feel a thunk thru the pedal, same thing when taking off from pulling up backwards(reverse parking for example) take off and first time foot goes on the brake.. Clunk..im guessing pad is slipping or something!?)
I cant afford to go the rear disc upgrade at the moment, so am just going to replace with standard pads both front n rear..
Just after some part numbers..
Rear shoes:
Rear pistons(?):
Front Pads:
any other suggestions or thigns I need to be aware of!? chime in ;)
Post Posted: Sun Aug 02, 2009 5:05 pm
http://www.suzistore.com.au/
where i get all my zook gear now
Post Posted: Sun Aug 02, 2009 5:07 pm
Check your axle seals and wheel bearings while you're there, as well as your rear wheel cylinders.
Doing a brake fluid flush probably wouldn't hurt either.
Vehicle: Zookless
Post Posted: Sun Aug 02, 2009 9:53 pm
Check the condition of your rotors, they may need to be machined.
Also measure the thickness, minimum is 8.5mm. If they need replacing you might as well upgrade to Vitara rotors and calipers. 8)
I like to pull out the manual and follow each page step-by-step. It reminds me of playing with Lego when I was a kid. :wink:
Post Posted: Sun Aug 02, 2009 10:32 pm
Fronts are DB403
rear can be a choice of about 5000 combos :)
Post Posted: Sun Aug 02, 2009 10:59 pm
lol yeah rears are silly, do you have a little hole or a big hole ? what the hell ? lols
Post Posted: Mon Aug 03, 2009 12:26 am
Go to better brakes in Bayswater.. :wink:
Post Posted: Mon Aug 03, 2009 12:33 am
cheers kenn! thats what I was after! I'll tell em Kenn n Grover sent us ;)
am after the whole lot, cylinders, shoes, pads.. im guesstimating $150ish..?
Post Posted: Mon Aug 03, 2009 12:36 am
yeah you should be able to get the lot for that :)
Post Posted: Mon Aug 03, 2009 12:40 am
They wont remember me ,so tell them Jamie from All Rangers 4wds sent you. :wink:
Post Posted: Mon Aug 03, 2009 10:33 pm
Cairnszook
curious about the vit rotor and caliper conversion. excuse my ignorance but how difficult is it to do. Is there a thread you know of covering this.
Vehicle: Zookless
Post Posted: Mon Aug 03, 2009 10:35 pm
Have a read through my build, and Damo's. It should be pretty well covered there.
Users browsing this forum: No registered users and 188 guests
