It is currently Tue Oct 20, 2026 9:37 pm
Vehicle: SJ80
Post Posted: Tue Aug 04, 2009 3:29 am
What are the body lift options for coilys?
My stock body rubbers are shot, buggered, perished, missing in action.
Already have lifted springs, not wanting to go to much higher with the body lift, but have to replace the body rubbers with something.
do 1" or even 1/2" body lift replacement rubbers exist?
Any ideas where I might find em?
suzistore.com.au have replacement stock body rubbers for $100.
Post Posted: Tue Aug 04, 2009 3:42 am
replacement body rubbers sounds like your deal man
Post Posted: Tue Aug 04, 2009 10:21 am
PM Just Cruizin on this forum. I'm sure he will able to help you out with either body lift or rubbers.
Post Posted: Tue Aug 04, 2009 5:03 pm
I do rubbers that are slightly higher then standard but only 2mm, made for polyurethane so won't perish like the rubber. Other then that I do a 50mm body lift. Try Locktup4x4 for a 25mm kit. For a 1/2" lift get some 12mm flat bar and drill some holes.
Vehicle: SJ80
Post Posted: Wed Aug 05, 2009 2:28 am
So does a body lift kit replace the standard rubbers, or would I need to replace the rubbers (the stock ones are completely buggered) as well as fit the kit?
Is a body lift kit the same for a coily as any other Sierra?
Post Posted: Wed Aug 05, 2009 12:03 pm
Just_Cruizin does body lifts and body mount replacements. You can do just the mounts or the mounts and lift.
Users browsing this forum: No registered users and 206 guests
