It is currently Wed Oct 21, 2026 4:36 am
Post Posted: Wed Aug 05, 2009 5:15 am
any other causes for rear main seals to go pre maturely, i don't think i even did any water crossings with this one in, looks like it is pissing out and it was a suzuki genuine seal :(
also i get oil going through the pcv (you can see it sitting in the inlet pipe) causing white smoke on start up, could i have to much positive pressure inside the engine or something ?
I'm relating my motors seal hating and start up smoke habits
Vehicle: SJ80
Post Posted: Wed Aug 05, 2009 7:25 am
My Coily pumps oil through the pcv to the air box.
I assume it is because the engine is a heavy breather. rings etc worn, lots of blow buy.
My rear main is also leaking, and I also wondered if that is in part due to a little to much pressure in the crank case.
Post Posted: Wed Aug 05, 2009 11:44 am
It could cause it, check the rocker breather isnt blocked at all?
Vehicle: '92 Sierra
Post Posted: Wed Aug 05, 2009 12:50 pm
If you overfill the oil it can cause the crank seals to fail. It would also explain the oil getting up into the pcv valve. But if you've replaced it and filled it to the proper level I would have thought that would rectify the problem. It shouldn't keep doing it. There could also be excessive scoring on the crank shaft but that wouldn't explain the PCV.
Post Posted: Wed Aug 05, 2009 1:06 pm
Blow by, worn rings
Post Posted: Wed Aug 05, 2009 3:28 pm
good idea i am yet to pull that one off.
oh and yeah and i forgot to mention it's a g13bb..
Post Posted: Wed Aug 05, 2009 6:54 pm
Lip seals can't hold pressure. They can only withstand a maximum of 5psi if your lucky.
A pcv valve blockage would easily exceed this.
weaves
Post Posted: Wed Aug 05, 2009 8:59 pm
if it was pressure related do you think that after i replace the pcv if that changes things that the seal will continue to work when not under this pressure ? or would it need to be replaced
Post Posted: Wed Aug 05, 2009 9:19 pm
my front main continues to work after doing the same when i folded the pcv hose in half and it blew that out.
there are alot of factors wether it will work or not. The main one being luck. If your lucky enough for it to pull back onto the shaft with no damage to the lip or the spring inside the lip you will be fine.
There is nothing to say it will or won't. But being a fresh, directional, silicone seal it has the best chance out of any. Being silicone its soft enough to pop back over, being directional, once that lip catch's it's going to be naturally drawn onto the shaft.
Give it a shot, it all depends on how far it blew out.
weaves
Post Posted: Wed Aug 05, 2009 9:37 pm
yeah hopefully it will work itself out, the crank was in good condition and everything when i put it in.
could blow by build up pressure in the right areas to do the same thing ?
Post Posted: Wed Aug 05, 2009 9:46 pm
Yes.
Post Posted: Wed Aug 05, 2009 9:50 pm
i get good compression numbers, can you still get good compression but have blow by ?
Post Posted: Wed Aug 05, 2009 9:59 pm
Yes.
What's the condition of the crankshaft around where the seal sits. It may need resleeving
Post Posted: Wed Aug 05, 2009 10:04 pm
it seemed fine when the seal was installed, the area was nice and clean the reason it previously leaked was it was rock hard.
Post Posted: Thu Aug 06, 2009 2:40 am
But was the sealing surface scored or worn from the previous seal. If so you may actually reaquire a speedi sleeve.
weaves
Post Posted: Thu Aug 06, 2009 3:14 am
yeah thats what i meant it did look nice and flat or else i would have sleeved it already :), speedi sleeves are so cool lol
Users browsing this forum: Google [Bot] and 323 guests
