It is currently Thu Oct 22, 2026 2:13 am
Post Posted: Thu Aug 06, 2009 11:49 pm
just got some new rubber bushes to go in and i want to look after these ones so i want to use the right grease on them.
ive got a tube a tube of these if they will be ok
Castrol APXT
A blue colored grease with enhanced tackiness for improved performance in operating conditions characterized by extremes of heat, vibration and dampness
Castrol EPL2
Chassis lube and wheel bearings.
Post Posted: Fri Aug 07, 2009 12:05 am
Either one should be fine its only to let the pins slip rather than squeaking and improve the life of the bushes also gives better ride quality.
Good question. I just bought some grease for my bushes today aswell.
PBR rubber grease. States its a castor oil based grease. Expensive though 110grms for $14.
What you really want to know is does it effect the rubber long term?
I think CASTROL OPTITEMP LG is the go.
Compatible with elastomers based on synthetic materials (e.g. NBR, CR) and Nrbase as well as with rubber.
http://www.castrol.com/castrol/productd ... Id=6004156
SS
Post Posted: Fri Aug 07, 2009 12:07 am
when i greae my bushes before. i usto grease basicly the whole bush so it will be free for movement in anyway. then i put a little bit of grease on the shackle where the bush sits to always that to slide nice
Post Posted: Fri Aug 07, 2009 12:24 am
grease kills rubber!
pbr rubber grease is for brake seals!!!
castrol make a rubber grease, washes off though
Post Posted: Fri Aug 07, 2009 1:09 am
ok then how do i keep them lubricated?
Post Posted: Fri Aug 07, 2009 1:25 am
X2 :?:
Post Posted: Fri Aug 07, 2009 1:29 am
Try a lanolin base grease. As far as i'm aware its ok on rubber.
Have been using it for quite a while and have'nt had any problems.
Hard to wash out, sticks to everything. As its not for high temp applications it should be alright.
Cheers.
Post Posted: Fri Aug 07, 2009 1:58 am
X2 :?:
rubber is suppposed to grip the metal surfaces and twist with it, not slide over it
another reason why urethane is better :)
Post Posted: Fri Aug 07, 2009 2:50 am
ok then well it would still need to be lubricated so it twist in the springs?
Post Posted: Fri Aug 07, 2009 3:00 am
no, the rubber twists in itself
Post Posted: Fri Aug 07, 2009 3:03 am
oooooooooooo i see. so you recon i shouldnt grease them?
Post Posted: Fri Aug 07, 2009 12:53 pm
You can grease them, but they will fall apart in the not to distant future. I was always using rubber because of its greater flex but got sick of replacing them. now use urethane and has been all good since
Post Posted: Fri Aug 07, 2009 2:24 pm
will a rubber grease be suitable? im am guessing it would be?
Post Posted: Fri Aug 07, 2009 2:34 pm
rubber grease won't kill the bushes, but it's pretty useless in the application- it's too light.
Lanolin sounds like a good option of you want to experiment with lubrication
HOWEVER - grit and sand stick to grease, and will then make a grinding paste that will flog everything out anyway.
IMHO regardless of what you do, you'll need to pull everything apart once a year so so for a clean up/bushing replace anyway.
I have seen some very soft urethane, but I'm not sure what their life will be like.
Post Posted: Fri Aug 07, 2009 2:42 pm
im in the process of putting somwOME springs in at moment. so no lube is the way to go yer? hope so cause i dont want to go and redo it all again.
Post Posted: Fri Aug 07, 2009 2:48 pm
OME springs come with urethane bushes which benefit from grease or the squeaking will drive you insane.
They do not require any sort of special grease AFAIK - urethane isn't (basically) affected by grease.
Post Posted: Fri Aug 07, 2009 5:38 pm
About 3 months before my fixed ends split :) lasted years in teh shackles though and that was 40 duro, very spongy :)
Post Posted: Fri Aug 07, 2009 9:36 pm
Steve beat me to it. If you do want to try Lanolin though, there's a product called Lanotec. Should be able to get it from Ripco and the likes I think
Post Posted: Sat Aug 08, 2009 3:37 pm
Supercrap also sells lanolin based grease in tubs.
Users browsing this forum: No registered users and 296 guests
