| brake + alt warning lights https://auszookers.com/forum/viewtopic.php?f=5&t=5908 |
| Author: | shep [ Fri Aug 07, 2009 1:16 am ] |
| Post subject: | brake + alt warning lights |
what would cause the brake and alt warning lights to come on at the same time. they come on together, have a random brightness and always disappear when i turn something on. eg: dash lights come on. switch on air con and the warning lights will go out. the alt is new and is charging fine and there is plenty of brake fluid. should i just put a bit of leckie tape over the lights and forget about it or is my car about to spontaneously burst into flames. some fucker did say nice jeep to me today, so it might happen. |
| Author: | sr20zook [ Fri Aug 07, 2009 1:23 am ] |
| Post subject: | Re: brake + alt warning lights |
hahaha jeep, just tape it! out of sight out of mind |
| Author: | royce [ Fri Aug 07, 2009 2:46 am ] |
snakes? is it easy to make em come on? does the temp and fuel gauges do funny things at the same time? some shitbox toyotas light up al the lights when the alternator goes funny but sierras dont have the same bulb check setup in them so I cant think of anyway that they are linked I doubt its something wierd like dropping ignition power to the dash and the alt feeding power back up to it cause that wouldnt make the oil light light up |
| Author: | Rockhopper [ Fri Aug 07, 2009 9:44 pm ] |
I'm guessing alternator or a bad earth somewhere. Cause it's a new alternator, doesn't mean it's not faulty. I've been caught out before. |
| Author: | shep [ Sun Aug 09, 2009 5:36 pm ] |
i think i have it worked out. when i wired up my second battery i had a bit of a smoky earth incident. i have put a heap of new earths on and it seems to be fixed. |
| Author: | DMAC [ Sun Aug 09, 2009 7:44 pm ] |
shep wrote: i think i have it worked out. when i wired up my second battery i had a bit of a
smoky earth incident. i have put a heap of new earths on and it seems to be fixed. Sorry just got a picture in my head that didn't involve milk crates. Like I said smoke makes electircs work don't let it out!!! |
| Author: | shep [ Sun Aug 09, 2009 10:15 pm ] |
just went for a lap and the lights are on if the motor is running fuckarseshitfuckenpieceofshit as soon as something else is on the lights turn off |
| Author: | TZAR [ Mon Aug 10, 2009 12:18 am ] |
shep wrote: just went for a lap and the lights are on if the motor is running fuckarseshitfuckenpieceofshit
as soon as something else is on the lights turn off Throw a milk crate at it...... |
| Author: | shep [ Thu Aug 13, 2009 4:04 pm ] |
finally have it worked out. when you get both the warning lights come on it means that the alt is over charging. i thought that 14.4 volts at idle with everything turned on was a bit to good. the alt is putting out 16.5v at 2000 revs. |
| Author: | Taff [ Thu Aug 13, 2009 4:56 pm ] |
I would agree with royce. Check for snakes under dashboard. |
