It is currently Wed Oct 21, 2026 2:08 am
Post Posted: Wed Aug 12, 2009 1:28 am
Hi All,
Can a 1lt T'fer case be used in a 98 sierra??? Wanting some better low range gearing. Any ideas?
Thanks
Adrian
Post Posted: Wed Aug 12, 2009 1:43 am
i think they fit but you need a leafie jack shaft, i could be wrong but.
Post Posted: Wed Aug 12, 2009 1:46 am
Thanks Shep
Post Posted: Wed Aug 12, 2009 1:55 am
pritty sure they fit,but you have to get one with a 4wd switch,and you have to change the flanges,as the 1l ones dontmatch up to the coily ones...also you may have to change the handbrake setup(1l have drum brake on the t/case for handbrake.)
Anyone feel free to correct me if im wrong? :P
Coily GTI Turbo...thats right its a coily!!
Post Posted: Wed Aug 12, 2009 1:58 am
oh yea i forgot about that stuff. :lol:
Post Posted: Wed Aug 12, 2009 2:17 am
Mr unique_seek is on the money.
Also, the front driveshaft ends up a bit too long (the coil case is shorter front to back than a gear drive sierra case)
Might be OK, but on the car I did eleventy years ago I recall we put a leaf front driveshaft in it.
Post Posted: Wed Aug 12, 2009 2:50 am
You don't have to use the handbrake drum, when i changed mine i just changed the rear flanges over as well and used my normal rear drums as the handbrake. Might be different on a coily but.
My Maruti build, Click WWW
Post Posted: Wed Aug 12, 2009 10:20 am
Hi All,
Thanks very much for the info, I am going to try the 1Lt case with the front shaft from a leafy and use existing handbrake from rear drums. Hopefully works out ok.
Post Posted: Wed Aug 12, 2009 12:13 pm
hey adrian if you need a leaf front drive shaft i'll swap one for the coilly one you got from me last night. cheers Jeff
Post Posted: Wed Aug 12, 2009 12:26 pm
Thanks jeff, cheers again for your help last night also.
Post Posted: Wed Aug 12, 2009 10:03 pm
f you run the fron leafy shaft..wont you have to change the front diff flange too?or at least get the shaft moded?
Ps let us know how you go as I will be doing this mod in the near future :lol: maybe some picks??hehe
Post Posted: Thu Aug 13, 2009 2:25 am
WT flanges are the same as coily, coily are just threaded, so you can use the coily bolts to bolt on the wt flange
Users browsing this forum: No registered users and 193 guests
