I was having a look at the Jimny auto im fitting in the lj and noticed that the slip yoke that slides in the back of the gear box appears to be a different size to the Wide track one. Can any one confirm
a) that it is indeed a different size.
b) what spline it is and if it is the same as any thing from another car. ( i.e vitara tail shafts
c) if any one has a jimny jack shaft or knows where a jimny is being wrecked.
Joined: Sat Oct 27, 2007 11:30 pm Posts: 14977 Location: The Hills
Posted: Tue Aug 18, 2009 3:04 am
tanshi wrote:
I was having a look at the Jimny auto im fitting in the lj and noticed that the slip yoke that slides in the back of the gear box appears to be a different size to the Wide track one. Can any one confirm a) that it is indeed a different size. They are different
b) what spline it is and if it is the same as any thing from another car. ( i.e vitara tail shafts vit is same as sierra, so no good there
c) if any one has a jimny jack shaft or knows where a jimny is being wrecked. I have one here from an auto jimny I don't need. Good umis, yours for $75. I can drop off at your place if you like.
Users browsing this forum: No registered users and 105 guests
