It is currently Thu Oct 22, 2026 4:15 pm
Post Posted: Thu Aug 20, 2009 12:37 am
Quick question for everyone: I got my zook engineer for everything, however with standard tyres. If i get pulled up with my 34" tyres on what are the conciquences? Also when I present the report to Vicroads will they ask to inspect the vehicle?
Everything is engineered besides the tyres....Its engineered for 205/75/r15
cheers
Post Posted: Thu Aug 20, 2009 1:08 am
duno I'm in nsw
 Profile YIM
Post Posted: Thu Aug 20, 2009 1:50 am
i think that youll get pulled up for it because there over 2inchs bigger then standard but i may be wrong
cheeers stephen
83 LWB,5" lift, rear locker,31's,custom bar work,
Post Posted: Thu Aug 20, 2009 2:02 am
you mean 7-8 inchs over standard size wheels
Post Posted: Thu Aug 20, 2009 1:47 pm
Shouldent be no more then being pulled over in a suz gti on 17's. They come 14"s stock
:blingbling:
(My guess)
Post Posted: Thu Aug 20, 2009 4:23 pm
If you get pulled up with an engineers report, if your car is as stated on the report they can only defect the car on normal stuff, non wokring lights, bald tyres etc. Having said that the car needs to match the report exactly, if you have 31" 10 R15 on the report and then you go to a16" rim but still a 31" tyre the report in not valid. By having 34" on it when its engineered with stock wheels it makes your report usless if you get pulled over and you can get a defect.
Found that out the hard way :cry:
Post Posted: Thu Aug 20, 2009 10:36 pm
X2 very well put
Post Posted: Thu Aug 20, 2009 11:59 pm
Also your car would be un roadworthy , therefore negating your insurance , good luck with that , Cheers Paul.
Post Posted: Fri Aug 21, 2009 2:56 am
Yes but if i do get done for it on the lager tyres will a I need to bring it back to the report spec to get roady or do i need to bring it to standard?
Post Posted: Fri Aug 21, 2009 12:03 pm
Just the report specs. I doubt they will defect the engineered stuff just a waste of time, they would do the tyres and other non listed stuff.
Users browsing this forum: No registered users and 87 guests
