It is currently Wed Oct 21, 2026 11:34 am
Post Posted: Fri Aug 21, 2009 4:04 pm
As question asks..
Maybe planing for my lwb..
Were they easy to fit?
Car may possible going from leafs to coils/coilovers.
They look piss easy, dont have to chase coil hats, springs, no seperate shocks. Unsure about bumpstops.
What the pricing like? Similar to a coil and shock price per corner?
Also are tey legal? I know i should ring an engineer, but they all seem to be busy atm! :lol:
Post Posted: Fri Aug 21, 2009 4:35 pm
As question asks..
Were they easy to fit? You will most likely need custom upper and lower mounts.
Car may possible going from leafs to coils/coilovers. Yes its possible, but you will need to run control arms like any normal coil setup.
They look piss easy, dont have to chase coil hats, springs, no seperate shocks. Unsure about bumpstops. You will still require an external bump stop. You can use the conventional rubber bump or go for the air bumps.
What the pricing like? Similar to a coil and shock price per corner? Not even close! My 10" fox coilovers ran in at $280US ea. Coils were an additional $160US per corner. Then there was $120US shipping per corner. Thats about $2400 US shipped. Thats about $2900 AUD 8O . I bought when we were trading at 98c to the dollar.
Also are tey legal? I know i should ring an engineer, but they all seem to be busy atm! :lol: They will need to be engineered along with your link suspension setup.
Vehicle: I drive your mum
Post Posted: Fri Aug 21, 2009 4:39 pm
We are using FOA 2.5 remote resoviour coil overs for the current tuff truck build (landcruiser, not zook :cry: ). Fatzook has pretty got you covered with the info there. You rig will have to be engineered, but they can be passes. We have talked to engineers and they are fine with them. If there is intersted enough for a build that isnt zook, i can start a thread on it.
Layto....
Post Posted: Fri Aug 21, 2009 4:40 pm
Layto....
Just start the thread already Armsup Tough truck builds are the exception :D
Post Posted: Fri Aug 21, 2009 5:22 pm
Awesome answers quick and informative :P
I like the look of em, But not the price :lol: Like any suzuki owner..
We will see. I may just go coils.. I need comfort for this new baby. Im over leafs. So is the missus..
Coilovers are completely adjustable yeah? Soft/hard etc.
Wont be doing tough truck or any comps. Just hardcore 8)
Post Posted: Fri Aug 21, 2009 5:43 pm
Coilovers should have adjustable vavling for the dampeners, and you can mix and match your primary and secondary coil rates to give whatever handling traits you want. :D Ride height fine tuning can be done by adjusting the coil seat height. For what your after, they may be overkill. A good coil/shock/link setup will do what you want for much less $$. But if you are dead keen on coilovers - go for it 8)
Layto....
Post Posted: Fri Aug 21, 2009 6:20 pm
Hi guys, its time for me to share abit of what i have done so far for a coilover proejct for my old grandvitara converted to front samurai axle.
I chanced upon this 4 US sites for spings:
http://swayaway.com/TechRoom.php
www.polyperformance.com
http://www.pagedezigner.com/bluecoil/progressive.htm
http://f-o-a.com/shop/index.php?main_pa ... ucts_id=11
I calculated my main and tender rate using the calculator provided at swayaway( pretty elaborate). I have my mech fabricating coilover holders and radius joint.
Just a question here, for those who did dual rate setup for their sierra, whats is your main and tender rate?
Post Posted: Fri Aug 21, 2009 6:23 pm
while you guys are discussing this, what do you guys think of air shocks?, has anyone had much experience with them and anything i should look out for when incorporating them into my suspension set up?
weaves.
Post Posted: Fri Aug 21, 2009 6:59 pm
Been doing a tiny bit of research myself into this.. hmmmm, how nice
Vehicle: 07 vvt jimny
Post Posted: Fri Aug 21, 2009 9:58 pm
8O holy... moly.... 8O
why isnt there a drool emotion :idea: lol
Vehicle: 75 Cruiser
Post Posted: Fri Aug 21, 2009 10:06 pm
Are you saying you'll take the baby and missus hardcore 4wding? :lol:
Can you do all the work yourself? it'll still cost heaps if you have to pay someone to do it.
Post Posted: Fri Aug 21, 2009 10:27 pm
Who's truck is that?
Vehicle: WR250F/Jeep XJ
Post Posted: Fri Aug 21, 2009 10:42 pm
Might have to register to read the link:
http://forum.mudrhino.com.au/viewtopic. ... highlight=
vn v6
turbo 700-hilux transfer
hilux diffs f & r
12 inch coilovers (front)
10 inch coilovers (rear)
f&r air lockers
3 link front end
"A" arm rear set up
extended wheel base
rear disc brake conversion
35 BFG krawlers on 10" bead lock rims
Low mount winch
Internal and external roll cage
Laminated diff housings
+ heaps more
Post Posted: Fri Aug 21, 2009 10:52 pm
holy moly that's got me thinking. i am sure ball has made coil overs for some sort of desert racing thing, i wonder if he would make some for me. :?:
Post Posted: Mon Aug 24, 2009 1:51 am
My baby is my new LWB WT...
My Missus is abit over 4wding..
Im over bouncing around..
Im a Fitter/Machinist/Welder.. Fabing up items is my thing 8)
Users browsing this forum: Google [Bot] and 113 guests
