It is currently Wed Oct 21, 2026 7:03 pm
Post Posted: Sun Aug 23, 2009 6:17 pm
how do coily rear axles compare to WT? i have what i think is a shortside WT but it seems to be about 15mm too long.
The car it came out of had bits and peices from plenty of different zooks and a custom coiled rear. I asumed it was WT because it had handbrake on the rear drums but the splines are bottoming out in the diff centre before the bearing gets into the housing.
So if coily axles are about 15mm longer it would explain everything....
Post Posted: Sun Aug 23, 2009 9:56 pm
i think they are about 15mm bigger. there was a thread on here recently someone was asking about them
Post Posted: Sun Aug 23, 2009 10:24 pm
As per the other thread I think coil is 17.5mm wider.
Post Posted: Sun Aug 23, 2009 10:53 pm
well thats just great :(
I lend friends parts and they replace them with the wrong thing.
wt longside turned out to be from a nt....
wt shortside is from a coily! :x :x
WT axles seem to be getting pretty damn rare these days...
Are chromo rears worth buying?
Post Posted: Sun Aug 23, 2009 11:17 pm
You can't just chop 15mm off the end with a dropsaw? surely the spline would still be long enough to sit further in?
Clearance Hole Technology :P
Post Posted: Sun Aug 23, 2009 11:30 pm
Yeah thats an option i guess. I put a brand new bearing on it too hah... i have two useless axles with brand new bearings!
Post Posted: Mon Aug 24, 2009 1:01 am
The coily axle with the WT bearing was a waste but the other one might be saleable..
Coily and WT bearings are different. :cry:
Post Posted: Mon Aug 24, 2009 1:14 am
how are they different?
Im going to have a go at trimming it down then if its useless to coily owners too hah
Post Posted: Mon Aug 24, 2009 3:57 am
I was given a pair of Coily bearings and stupid me fitted them without checking first... I can't remember if they are bigger or smaller but they certainly don't fit.
Post Posted: Mon Aug 24, 2009 10:59 am
They are the exactly same as a WT. The ones you had were not coily bearings.
Users browsing this forum: Google [Bot] and 146 guests
