It is currently Wed Oct 21, 2026 11:34 am
Post Posted: Sun Aug 23, 2009 12:19 am
I have a late model Jimny power steer pump that has a idle up switch solenoid thing on pump; can someone who has a jimny tell me where this wire goes to on theirs.
David
P.S. maybe a wiring diagram would help also
Zuki
Suzuki Sierra 1990 Hardtop
Now just drive i
Post Posted: Sun Aug 23, 2009 12:30 am
your fitting to sierra? in a jimny thet goes to the ecu so it can adj the idle for
the power the p/steer pump uses, prevents stalling.
Steve
Post Posted: Sun Aug 23, 2009 12:33 am
Steve
Yes Steve I have put it in a Sierra surely it could be wired into the idle up circuit. the same one that idles up when lights are turned on ETC
David
Zuki
Now just drive i
Post Posted: Sun Aug 23, 2009 12:44 am
Steve
David
It is possible but not worth the hassle... I run a large Toyota pump on my Sierra and the effect it has on idle speed is negligible.
Post Posted: Sun Aug 23, 2009 12:49 am
I haven`t done it in a sierra but you can use a relay to power the idle up, the switch on the pump will switch earth, so give the relay power to switch & 12v pins with no earth as you`ll use the p/s switch to trigger earth completing the curcuit, put the acc pin to solinoid.
Steve
Post Posted: Sun Aug 23, 2009 1:41 am
David
In the downloads section mate i've uploaded the service manual for the Jim , try that , it has the diagrams i'm pretty sure.
Post Posted: Sun Aug 23, 2009 2:34 am
I run jimny p/s box with a vit pump on my 1600, when its cold (its been very cold here of a morning and I dont run a choke on my webers) it labours a little but once warmed up its fine.
Is yours up and running or are you still fitting it as you may be worrying over somthing that mighten be a problem.
Nik
No zooks just VWs
Post Posted: Sun Aug 23, 2009 2:46 am
Nik
Yes it is up and running only finished today, have not had a chance to try out on the dirty stuff. It appears to handle the pump ok (the idle that is) I was just wondering if the wire up would help that was all
David
Zuki
Now just drive i
Post Posted: Sun Aug 23, 2009 4:15 pm
Cool you will love the p/s 8)
Ive only noticed the extra load this winter but as I said I dont run a choke so my 1600 idles at 500rpm until warm so it labours a bit when turning and the power isnt really there but as soon as its up to temp its all good.
Nik
No zooks just VWs
Post Posted: Sun Aug 23, 2009 9:38 pm
Nik
Nik, Your right the PS is awesome; i think i will need to install a oil cooler for it though. In tight technical tracks and in conjunction with the air temperature the oil does get extremely hot.
Do you run a cooler if so what type is it.
David
Zuki
Now just drive i
Post Posted: Sun Aug 23, 2009 10:01 pm
Ive thought about running a cooler but as yet I havnt. If I go to that lenght I will mod the pump for more pressure and flow (think its talked about on zuwharrie)
So far Ive run 33s at 5psi in rocks and Ive had the 35s down to 10psi in "normal" type stuff Im still waiting to see how it handles the 35s aired right down!
Nik
No zooks just VWs
Users browsing this forum: No registered users and 112 guests
