https://auszookers.com/forum/
inboarding rear shocks
https://auszookers.com/forum/viewtopic.php?f=5&t=6224
Author:  keechox [ Tue Aug 25, 2009 11:50 pm ]
Post subject:  inboarding rear shocks
was reading a post last week or maybe two ago about inboarding rear shocks and how to do it on the cheap with a bit of 50x4 steel?????, now ive decided to do it and cant find the thread grrrrrrrrrrrrrrrrrrrrrrrrrrrrrr
help, my back end is too bumpy :oops:
(and yes i did try searching)
Author:  shep [ Wed Aug 26, 2009 12:22 am ]
Post subject:  Re: inboarding rear shocks
there really is bugger all to it. this is one i got from locktup4x4 and my
other sierra has a homemade one in it. i will take a photo of it tomorrow
Author:  just_cruizin [ Wed Aug 26, 2009 2:59 am ]
If you have a body lift bolt some 50x25 on top of the cross member with some 1/2" bolts welded in. Won't flex like the flat bar.
Author:  dank [ Wed Aug 26, 2009 3:42 am ]
Hey shep whats going on with your exhaust? :D
In re: to tech, i have drilled and bolted a bit of 50x50x4 RHS so it bolts onto the stock shock mounts and allows inboarded shocks in two locations. Easy to do. I've got some pics somewhere
Author:  shep [ Wed Aug 26, 2009 3:49 am ]
that's not the exhaust it is the awesome tube. :wink:
Author:  shep [ Fri Aug 28, 2009 3:08 pm ]
my exhaust is awesomely awesome 8O
this is my lwb. it looks like it is a bit of 30x30 that is welded in.
Author:  alex [ Sat Aug 29, 2009 10:05 pm ]
does your shock hit the diff when flexed on your LWB shep???? looks close?
Author:  shep [ Sun Aug 30, 2009 12:12 am ]
dunno mate, only got it running today. i bought it with a dead motor.
Author:  alex [ Sun Aug 30, 2009 12:16 am ]
ok, that would be a good angle for mine thats if it doesnt hit the diff :?
Author:  alex [ Sun Aug 30, 2009 12:17 am ]
Author:  shep [ Sun Aug 30, 2009 12:40 am ]
hopefully i will be able to let ya know tomorrow.
Author:  alex [ Sun Aug 30, 2009 2:30 am ]
:cheers: 8)
Author:  BlueSuzy [ Sun Aug 30, 2009 5:50 pm ]
my shocks hit the diff with woosy hilux shocks in stock positions and diff moved 15mm rearwards. (stupid brake line mounts)
Author:  shep [ Sun Aug 30, 2009 5:57 pm ]
there is heaps of room, doesn't even look like touching.
Author:  bron5on [ Sun Aug 30, 2009 7:30 pm ]
Can the rear spring plates be rotated and or swappped to move the bottom shock mount to the front of the diff? When i put my new ranchos in they ended up with nasty dents in them before i removed the brake line mount. It's too wet for me to head out and have a look myself! I guess the inboarded mounts could be moved rearwards maybe. Any thoughts?
Bronson
Author:  alex [ Mon Aug 31, 2009 2:09 am ]
sweeeet :D i will be doing it that way, except i will use the original shock mounts to hold the shock bar.
Thanks shep :youdaman:
