| Gear movement https://auszookers.com/forum/viewtopic.php?f=5&t=6371 |
| Author: | lump_a_charcoal [ Tue Sep 01, 2009 11:08 pm ] |
| Post subject: | Gear movement |
I am in the process of installing my 6.5 gears. I have put the low and high speed gears onto the shaft, however there is a slight bit of play with the low speed gear. It moves side to side (not twisting) by less than half a mm, and the high speed gear is a tad less - Is this OK? Mecho at work reckons it is OK, but I wanna check with techsperts. |
| Author: | Taff [ Wed Sep 02, 2009 1:11 am ] |
| Post subject: | Re: Gear movement |
I recently removed Rockhopper S3 gears that had been in for 3.5 years and they had a bit of play, replaced with trailmaster 6.5 and same amount of play. I figured it was normal. You could probably shim between the spacer ring and the gear if you were a bit worried. Also the 6.5s have done one trip now, very quiet at highway speeds. Only whine a bit at 40-50km/h. |
| Author: | 11_evl [ Wed Sep 02, 2009 11:37 am ] |
Taff wrote: I recently removed Rockhopper S3 gears that had been in for 3.5 years and they had a bit of play, replaced with trailmaster 6.5 and same amount of play.
I figured it was normal. You could probably shim between the spacer ring and the gear if you were a bit worried. Also the 6.5s have done one trip now, very quiet at highway speeds. Only whine a bit at 40-50km/h. selling or sold rockhopper ones?? |
| Author: | Taff [ Wed Sep 02, 2009 7:28 pm ] |
Exploded them
| Author: | TASSIETOYUKI [ Wed Sep 02, 2009 8:16 pm ] |
Taff wrote: Exploded them
Are you sure there is a problem with them... All of the "Rockhopper" gears i have seen looked like that |
| Author: | brendan [ Wed Sep 02, 2009 8:43 pm ] |
![]() fucken awesome! |
| Author: | Rockhopper [ Thu Sep 03, 2009 1:16 am ] |
I had a slight amount of play in mine when I rebuilt the transfer, but it's been fine. Not really any noisier on the road, sounds a bit whinier than a standard transfer case when I'm crawling, but nothing too bad. I just figured it was pretty normal considering the size of the gears. |
