It is currently Wed Oct 21, 2026 3:41 pm
Post new topic Reply to topic  [ 34 posts ]  Go to page 1, 2  Next
Post Posted: Sun Sep 06, 2009 3:42 pm
does anyone know where ot get them for sierra? standared rotors now have a big gouge out of them from mud and causing the car to ver to the right when braking.
Post Posted: Sun Sep 06, 2009 3:51 pm
There is a thread in ere about vit vented rotors & calipers for sierra upgrade
Post Posted: Sun Sep 06, 2009 8:23 pm
Direct fit?
Post Posted: Sun Sep 06, 2009 9:47 pm
CairnsZook has done it, check his build up.
Vehicle: Zookless
Post Posted: Sun Sep 06, 2009 11:56 pm
Yeah, pretty much a direct fit, as long as you use Vit calipers too.
Rotors are not slotted or drilled, they are still "smooth" like the sierra ones, but they are ventilated.
You may just be able to get your existing rotors machined.
Post Posted: Mon Sep 07, 2009 12:54 am
I've done the vitara brake upgrade. It is awesome to say the least 8) Well worth it.
You need the front calipers and rotors off a LWB vitara estate. You only need to trim the brake rotor backing plate a bit because the vit calipers are larger. Other than that they are a straight bolt on
I'd suggest getting the calipers reco'd and just buying brand new rotors.
Member of C.O.R 4x4
Post Posted: Mon Sep 07, 2009 2:10 am
I was hoping to get some drilled ones so the mud doesn't gouge out the rotor
Vehicle: LWB Sierra & XL7
Post Posted: Mon Sep 07, 2009 2:27 am
X 2
Slotted rotors make a big difference in braking performance and if you have the spare coin go for it but Don't get cross drilled rotors. They won't last as long because they develop hairline cracks on the outer edges of the holes which eventuates with a cracked disc, Very common sight on the racetrack, They are especially prone to cracking when you hit water, mud etc. Also I'm quite sure they can't be machined where as the slotted rotors still can.
Post Posted: Mon Sep 07, 2009 11:31 am
so just plain slotted are the go. Do they make them to suit sierra? Or vitara
Post Posted: Mon Sep 07, 2009 12:05 pm
They can, they just use a different machining tip (and charge you accordingly)
Post Posted: Mon Sep 07, 2009 3:12 pm
DBA Make them for all cars.
Post Posted: Mon Sep 07, 2009 3:46 pm
your right. i had a look of DBA web site. am i better off swapping to vitara brakes with sloted rotors?
i just had a look at the specs for the vitara and sierra rotors.
VITARA 4 door estate LWB (91-98 )
Front Disc Diameter Height Thickness Min. Thickness Center Hole Bolt Holes
mm 287 46 17 15 107 5
sierra sj70
mm 290 46.5 10 8.5 107 5
Post Posted: Mon Sep 07, 2009 8:14 pm
All you'll need are the calipers to do the vitara conversion, so thats another $50 or so.
After replacing the brakes in my Vit, I kinda wish I went slotted. Maybe because I've used them in my previous cars and I can notice the difference. Changing the 20 year old brake lines would also make the pedal feel less spongey.
'92 Vitara & Camper trailer
Post Posted: Mon Sep 07, 2009 10:58 pm
would i be better of using the vit rotors too because they are thicker? or just get some sloted sierra ones?
Post Posted: Mon Sep 07, 2009 11:21 pm
In my opinion, I think you should just get replacement slotted rotors and decent pads. It's the cheaper option, They'll do what you want them to do, clear dirt off the face and generally improve braking.
If you use Vit calipers, of course you have to use vit rotors and pads. My previous car's that I done brake conversions on, I've had to replace the brake lines and the master cylinder. I'm not sure if it's the same deal with the zooks.
Post Posted: Tue Sep 08, 2009 1:59 am
Simple solution... Steer clear of mud :mrgreen:
It generally stuffs more than just brakes :wink:
Member of C.O.R 4x4
Post Posted: Tue Sep 08, 2009 3:32 am
Swift master, regardless of upgrade makes a huge difference.
Yer I'm not a fan of mud or water but somtimes it's unavoidable
Post Posted: Tue Sep 08, 2009 4:50 am
and fun.. :)
After getting out of mud, give the brakes a few stabs to make sure the pressure is still there.
Just another little trick from the race track that I apply to everyday driving, when your pulling up to a set of lights, just brake slightly, let go and re-apply the brakes, notice how the pedal is firmer.
Also a good idea to do that before going down a steep hill or towing.
Vehicle: '92 Sierra
Post Posted: Tue Sep 08, 2009 11:50 am
I just make sure I start braking far enough away from lights :P
Post Posted: Tue Sep 08, 2009 12:54 pm
yup i know the double brake tap. Why does it do that? Might ring the wreckers today see if they got any lwb vit calipers.then il track down some slotted vit rotors
Post Posted: Tue Sep 08, 2009 10:45 pm
Less air in the brake booster makes for a harder pedal
Post Posted: Tue Sep 08, 2009 10:53 pm
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM
Like that!! peaceout
Post Posted: Tue Sep 08, 2009 10:57 pm
it's true though
Post Posted: Tue Sep 08, 2009 10:59 pm
it's true though
Could be out of fuel!!!
Post Posted: Sun Sep 13, 2009 2:11 pm
ok this si happening. im tracking down some vit calipers. if i use vit calipers do i have to use the vit rotors too?
Post Posted: Sun Sep 13, 2009 2:49 pm
Yep. They are vented and thicker than sierra ones
Member of C.O.R 4x4
Post Posted: Sun Sep 13, 2009 3:09 pm
yer. im going to buy the sloted vit rotors from DBA. just finding calipers is the hard part
Post Posted: Sun Sep 13, 2009 3:51 pm
Cant be that hard. Suzi 4 will have them for sure.
Post Posted: Sun Sep 13, 2009 5:48 pm
Yep thats where I got mine from. Cant remember exact price but I was able to get 2x vit calipers, get them fully reco'd by a brake place, get brand new rotors and pads, all for about $450 all up Armsup
Member of C.O.R 4x4
Users browsing this forum: Google [Bot] and 105 guests
