| recovery points? https://auszookers.com/forum/viewtopic.php?f=5&t=6772 |
| Author: | revived [ Mon Sep 21, 2009 9:14 pm ] |
| Post subject: | recovery points? |
Recently my mate has given me 2x tow eyes that say WLL0.7t. Im assuming that this means that they are rated at 700kg. If i have one on either side on the front of my 83 suzi linked together by a rated chain will these be sufficient/safe for me to use as recovery points? If not what rating should i be looking at getting? |
| Author: | Fatzook [ Mon Sep 21, 2009 9:24 pm ] |
| Post subject: | Re: recovery points? |
No. These are designed for lifting things. The momentary force placed on your recovery points when being snatched is more like a few ton. Buy some rated hooks from arb/ tjm etc and fit those through the chassis with G8 high tensile bolts. Where possible use a sandwich plate inside the chassis rail to help prevent the rail from tearing. JMO Pete |
| Author: | revived [ Mon Sep 21, 2009 9:54 pm ] |
thanks for the quick answer. |
| Author: | steak_knife [ Mon Sep 21, 2009 11:03 pm ] |
Fatzook wrote: No.
These are designed for lifting things. The momentary force placed on your recovery points when being snatched is more like a few ton. Buy some rated hooks from arb/ tjm etc and fit those through the chassis with G8 high tensile bolts. Where possible use a sandwich plate inside the chassis rail to help prevent the rail from tearing. JMO Pete X2 |
