| how 2 remove the metal bracket behind plastic kick panel https://auszookers.com/forum/viewtopic.php?f=5&t=7056 |
| Author: | nandor85 [ Wed Oct 07, 2009 2:20 am ] |
| Post subject: | how 2 remove the metal bracket behind plastic kick panel |
hey guys just wondering how do i remove the metal bracket behind ya kick panel plastic should i just drill the spot welds out? the reason i want 2 remove this is cause im making up some custom sliders like these |
| Author: | parfittron [ Wed Oct 07, 2009 2:40 am ] |
| Post subject: | Re: how 2 remove the metal bracket behind plastic kick panel |
get a grinder, and just grind them down finely - they are only spot rivet type things. Once you get the bracket ground down far enough, they should just pop off easy. Then sand the heads back. Thats how I did mine anyways and it was really neat and pretty simple, just take your time. |
| Author: | just_cruizin [ Wed Oct 07, 2009 3:10 am ] |
Use a 1mm grinding disc. easier for fine work |
| Author: | parfittron [ Wed Oct 07, 2009 3:32 am ] |
ahh yea should have specified that, sorry! |
| Author: | Saam [ Wed Oct 07, 2009 4:02 am ] |
spot weld drill bit |
| Author: | hooki [ Wed Oct 07, 2009 7:00 am ] |
grinder and flappa disc. |
| Author: | twitchy [ Wed Oct 07, 2009 10:56 am ] |
http://cgi.ebay.com.au/H-S-S-3-8-10mm-R ... 911.c0.m14 these are brilliant |
| Author: | Damo [ Wed Oct 07, 2009 11:36 am ] |
The spot weld bit works good, but if you are a bit rough like me you might end up with a 10mm hole in your sill |
| Author: | Scrawny [ Wed Oct 07, 2009 2:50 pm ] |
hooki wrote: grinder and flappa disc.
This is what I used. Quick and easy with no holes left when you're done. I used a thicker disc though, 3-4mm? thick. It was easier to use a big blunt edge than a fine edge. Just go really slowly so you don't end up grinding the sill as well. |
| Author: | brendan [ Wed Oct 07, 2009 3:01 pm ] |
i just drilled them out, when i stuck the cheaker plate on just make sure there sikaflex on the holes |
| Author: | nandor85 [ Wed Oct 07, 2009 9:04 pm ] |
cheers 4 all the input guys |
| Author: | nandor85 [ Wed Oct 07, 2009 9:41 pm ] |
ive just taken the drivers side off and not even any surface rust i ended up using my dremal with a grinding disk on it worked a treat will little marking underneather so thats 1 down now i got 2 get my ass round 2 getting the other 1 off lmfao |
