| Author |
Message |
Junior_91
Joined: Tue Mar 17, 2009 10:30 pm Posts: 1084 Location: Ipswich
 Posted: Sat Oct 10, 2009 11:18 pm |
I just swapped my diffs under my 1993 SWB WT and my 1987 LWB WT and the tail shaft doesn't bolt up is this becuase they have a different pinnion yoke and are they interchangeable???
Any help would be greatly appreciated.
_________________ TWIN LOCK IT & JUST DRIVE!
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13017 Location: Melbourne
 Posted: Sat Oct 10, 2009 11:54 pm |
correct. WT and NT have different pinion flanges.
The easy way to fix this is to swap the transfer flanges, or swap the yokes on your tailshafts to suit, or swap 1/2 your tailshafts so the short end is NT and the long end is WT.
Don't pull the pinion flanges off and swap them - you'll screw up the pinion bearing preload and destroy the diffs.
Junior_91
 Posted: Sun Oct 11, 2009 12:33 am |
But if i know how to do it properly i can change them?
I have installed a locker into it so i know what i am doing is this possible?
shep
Joined: Thu Mar 29, 2007 11:30 pm Posts: 14498 Location: Here there everywhere
 Posted: Sun Oct 11, 2009 1:37 am |
it is possible if you get a new crush tube and set the diff up from scratch.  if you do you may as well get a new pinion bearing and seal as well.
steak_knife
Joined: Fri May 22, 2009 11:30 pm Posts: 21335 Location: Smart Ass Island
 Posted: Sun Oct 11, 2009 3:29 am |
shep wrote: it is possible if you get a new crush tube and set the diff up from scratch.  if you do you may as well get a new pinion bearing and seal as well.
X2, good on ya shep.
_________________ I used to be indecisive,
Junior_91
 Posted: Sun Oct 11, 2009 5:38 am |
So it will fit? Just wanna make sure.
Gwagensteve
 Posted: Sun Oct 11, 2009 12:39 pm |
Yes, it will fit, but that's a whole lot of work to "fix" something that doesn't need fixing. If you are pulling your diffs apart anyway, go for your life, but why open up a diff when there's no need?
You didn't explain which way round you were swapping, but the larger WT flange is superior - it runs bigger bolts- so if your diffs have the large flange that's what I'd be keeping.
xedent
Joined: Mon Jun 15, 2009 11:30 pm Posts: 895 Location: Sunshine Coast, QLD
 Posted: Thu Mar 10, 2011 10:02 am |
How do you torque these up if i have the new crush tube etc do you have to take the center out or what ?
_________________ My Maruti build, Click WWW
mr_ron
Joined: Fri Jan 28, 2011 8:16 am Posts: 279 Location: Beenleigh, Qld
Vehicle: Vitara
 Posted: Fri Mar 11, 2011 6:58 am |
I went from NT diff centerS(Small flange) in NT housing to the wt diff centers(big flange).. i just got some WT drive shafts and they fit like the NT ones..
_________________ Repping it, High Top style!
BlueSuzy
 Posted: Fri Mar 11, 2011 9:08 pm |
Lwb Wt flanges are Nt. Including jackshaft and transfer flanges.
Swb Wt flanges are all Wt.
31zook
Joined: Tue Mar 24, 2009 10:30 pm Posts: 9242 Location: maito
 Posted: Fri Mar 11, 2011 9:10 pm |
but 1.3 lwb sierra's are nt flanges
shep
 Posted: Fri Mar 11, 2011 9:48 pm |
my LWB has wt diff flanges  but only because it has wt diffs
my front tail shaft is all wt and my rear is half wt and half nt because i
wanted to keep the transfer handbrake.
_________________ JEEPJEEPJEEPJEEPJEEPJEEPJEEPJEEPJEEP
BlueSuzy
 Posted: Fri Mar 11, 2011 11:40 pm |
31zook wrote: but 1.3 lwb sierra's are nt flanges
All lwb are Nt flanges..
TZAR
Joined: Tue Aug 01, 2006 11:30 pm Posts: 3461 Location: licking some windows
Vehicle: LJ20 LJ50
 Posted: Sat Mar 12, 2011 4:07 am |
BlueSuzy wrote: 31zook wrote: but 1.3 lwb sierra's are nt flanges  All lwb are Nt flanges..
what about maruti's? aren't they lwb with wt stuff under them in the later models????
_________________ Camels have nice toes
remydog05
Joined: Sun Nov 23, 2008 10:30 pm Posts: 1260 Location: Vic
 Posted: Mon May 23, 2011 3:13 am |
Whats the easy way to tell if the flange you have is WT or NT?
The bolts are bigger in WT? But does the flange also measure larger??
JrZook
Joined: Tue Aug 08, 2006 11:30 pm Posts: 5517 Location: Holland Park
 Posted: Mon May 23, 2011 3:49 am |
BlueSuzy wrote: Lwb Wt flanges are Nt. Including jackshaft and transfer flanges. Swb Wt flanges are all Wt.
88.5 no deal
_________________ Lil Foot!
http://tiny.cc/gtsw1
Fatzook
Joined: Sat Oct 27, 2007 11:30 pm Posts: 14977 Location: The Hills
 Posted: Mon May 23, 2011 4:11 am |
You've been around zooks long enough to know that even suzuki doesn't follow their own rules
I've seen quite a few oddball zooks with parts from other models OEM fitted.
And 1L LWB are not the same flange as 1.3 LWB.
_________________ 2013 GV 1998 SV420 ute
