https://auszookers.com/forum/
Side Gear Wear
https://auszookers.com/forum/viewtopic.php?f=5&t=7590
Author:  Rhino [ Thu Oct 29, 2009 12:45 am ]
Post subject:  Side Gear Wear
Just wondering how much wear is allowable on side gears for lock rights to operate correctly. It’s a bit worn and glazed on the right hand side of the teeth but the top and left sides still seem to be alright.
Cheers Ryan
Author:  ninjadaniel [ Thu Oct 29, 2009 1:11 pm ]
Post subject:  Re: Side Gear Wear
No sure man, but i read on here somewhere that not using the couplings causes the lockrights to make more noise and wear out very fast
Author:  Rhino [ Fri Oct 30, 2009 12:35 am ]
Yeah I thought about getting a set of couplings for it but i haven't been able to find anywhere that sells the couplings without having to get them specially imported.
Author:  ball [ Fri Oct 30, 2009 12:38 am ]
If you have the lockers without the couplings then you can't just add the coupling as the locker halves are different.
Author:  Rhino [ Fri Oct 30, 2009 12:55 am ]
ahhhh.....true. Would I be better off looking around for a set of second hand side gears in better condition than mine are and using them or should I just stick mine in and hope for the best?
Author:  DMAC [ Fri Oct 30, 2009 2:06 am ]
Man your foot tappin', hand wavin', singin, mexican is making me dizzy.
